Slotted Vs Drilled
Old Feb 29, 2008 | 02:20 PM
JRYAN350Z's Avatar
JRYAN350Z
Default Slotted Vs Drilled
Buyin new rotors for my Brembo setup and a question came to mind.. Not so much the difference between the 2 but as far as performance during everyday drivind and street use which is the better way to go???? DRILLED OR SLOTTED..??? Thanks as always guys..So glad to have access to you guys
Old Feb 29, 2008 | 02:22 PM
bboypuertoroc's Avatar
bboypuertoroc
Do not get drilled. I wouldn't trust them as far as I could throw my Evo. Either get slotted or regular face.
Old Feb 29, 2008 | 02:47 PM
aznriceball2's Avatar
aznriceball2
drilled cracks. Get slotted for the looks, not sure if it has any performance gains.
Old Feb 29, 2008 | 02:59 PM
hbenet's Avatar
hbenet
Had this same question myself.
Tirerack even has this note:
http://www.tirerack.com/brakes/brake...+Drilled+Rotor
"NOTE: Brembo Sport drilled brake rotors are not recommended by The Tire Rack for track use or intended to be used in conjunction with race compound brake pads on the street. For severe duty brake demands see Brembo Sport slotted brake rotors."
Old Feb 29, 2008 | 03:05 PM
rkemp1's Avatar
rkemp1
slotted will help to vent the built up gases away from the pad which in turn will reduce fade to some degree. As previously stated drilled rotors tend to crack under high heat. Slotted are more reliable and a nice upgrade from stock.
Old Feb 29, 2008 | 06:23 PM
JRYAN350Z's Avatar
JRYAN350Z
Well as always my fellow members thank you once again. The amount of time aggravation and money wasted without the help of this site can not be measured... THANK YOU!!!!!
Old Mar 1, 2008 | 10:04 AM
Q45tech's Avatar
Q45tech
Any method [drilled/slotted] used to remove mass from the rotor will increase rotor temperature vs a plain solid unit under identical street conditions.
Old Mar 1, 2008 | 11:22 AM
350ZTheStandard's Avatar
350ZTheStandard
Mine are both slotted & drilled, with 3 full track days on this setup I have experienced no problems. I also am using SS brake lines and dot4 brake fluid and Hawk HKS pads. Before I purchased, eveybody on this site were telling me the slotted rotors would eat the brake pads real damn quick, only 14,000 miles and no wear, warping or cracking problems.
The cool thing about this site is that we are partial to our specific setups, so everything else is $hit,, even if they don't have a BBK on their Z cars some make comments.
Old Mar 1, 2008 | 11:26 AM
DavesZ#3's Avatar
DavesZ#3
One of your choices needs to be "Neither".
Old Mar 1, 2008 | 01:59 PM
350ZTheStandard
Why? Can you please elaborate???
Old Mar 1, 2008 | 02:06 PM
T_K's Avatar
T_K
F1 doesn't use cross drilled or slots.
TK
Old Mar 1, 2008 | 04:41 PM
DavesZ#3's Avatar
DavesZ#3
Most people are buying them for the bling factor, not for any real performance gain. As many have pointed out, drilled are an all around bad idea. Slotted have some benefit to offer, but for the daily driver it probably make absolutely no difference at all.
This subject has been discussed several times, here's one recent example....
https://my350z.com/forum/brakes-and-suspension/280605-brake-discs-drilled-slotted-both-or-neither.html
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
RWDBajan
Sep 17, 2015 04:52 PM
3vilbunny
Sep 13, 2015 12:31 PM
