Strange noise from StopTech brakes
Old Mar 17, 2008 | 05:50 AM
semtex's Avatar
semtex
Default Strange noise from StopTech brakes
I recently upgraded by brakes to the StopTech kit (355mm rotors w/ 4-piston calipers, front and rear). The brakes are great -- they stop really well, look good, etc. There's just one small problem. The left front squeals any time I put load on it, with my foot OFF the brakes. In other words, if I'm turning left, like just coasting in a parking lot or leaving the line at an intersection, it squeals. No problems at all when my foot is actually on the brakes, just when my foot is off. My mechanic has checked everything and can't find any problems. He has been able to determine that the squeal is caused by the pad slightly dragging when I'm turning left. We've tried three different sets of pads (Axxis, Mintex, and EBC), and they all squeal to varying degrees. My mechanic has been in touch with StopTech and they say they've never heard of anything like this, and agree that it's not a pad issue. My Z has never been in a fender bender or anything, it only has 9000 miles on it. We were initially torquing the lug nuts to 90 lbs/ft, but then increased it to 100 lbs/ft and the noise went away for a day, but now has come back.
Any ideas?
Old Mar 17, 2008 | 06:20 AM
DaytonaRoadster's Avatar
DaytonaRoadster
its probley just slighty uneven pad just touching the rotor, it will go away in a few hundred miles or so
Old Mar 17, 2008 | 06:22 AM
semtex's Avatar
semtex
With three different sets of pads?
Old Mar 17, 2008 | 06:25 AM
DaytonaRoadster
oh right didnt see that, maybe the calipers need adjusting?
Old Mar 17, 2008 | 06:33 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
Its probably due to hub flex since Zs are prone to that. On the racetrack where side loading forces are much greater, you would probably experience pad knockback, but under normal driving there is just enough deflection to let the rotor come into contact with the pads. Theres more info on pad knockback and hub flex on our website here:
http://www.stoptech.com/tech_info/wp_knockback.shtml
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
