brake pad question
Old Apr 25, 2008 | 05:27 AM
JJ19's Avatar
JJ19
Default brake pad question
i currently have nismo r-tune pads in the front and plan on replacing the rears with oem brembo pads? will this cause any problems or do i have to match the front and rear with nismo r-tune pads?
Old Apr 25, 2008 | 10:08 AM
j.arnaldo's Avatar
j.arnaldo
Turn your discs!, THEN install whatever brand of pads you choose.
Old Apr 25, 2008 | 11:54 AM
BeerViper's Avatar
BeerViper
you don't even need to resurface the rotors if they're not warped ... just bed the new pads in immediately after installation.
Old Apr 25, 2008 | 12:06 PM
julian's Avatar
julian
you don't have to match front and rear pads. the brake bias will change though.
and +1 on not turning the rotors.
Old Apr 25, 2008 | 12:08 PM
HondaKiller's Avatar
HondaKiller
it probably wont have much affect, it is not necessary, but you should turn the rotors after each pad install so the new pad has a clean surface to bond to upon bedding them in.
Old Apr 25, 2008 | 12:27 PM
BeerViper's Avatar
BeerViper
That is why you bed the brakes... no reason to make the rotors any thinner as long as there aren't any grooves or pad transfer (warping)
Old Apr 25, 2008 | 01:12 PM
JJ19's Avatar
JJ19
thanks for the input everyone. yea i did not turn the rotors, just did the "bed-in" method
Old Apr 25, 2008 | 01:42 PM
I don't see any problem. Of course avoid putting different pads on the same axle.
samansharif
Sep 25, 2015 12:31 PM
