Grinding engine noise after spring install...
Old May 12, 2008 | 06:50 AM
JMS71585's Avatar
JMS71585
Default Grinding engine noise after spring install...
I just had some tein s-techs installed on my Z. But for some reason, i'm feeling a rumbling/vibration when the car is started and when i step on the gas. I noticed my top plenum and some of my engine cover is hitting my font strut bar. I had a plenum spacer installed a while ago but that was installed correctly, with the stut bar washers/spacers. So i think this excessive rumbling is coming from the strut-bar and plenum grinding on each other. Anyone ever hear of this happening after a simple spring install?
I didn't do the spring install myself because i don't have the necessary tools.
Old May 12, 2008 | 07:00 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
check strut bar bolts.
Old May 12, 2008 | 07:06 AM
JMS71585's Avatar
JMS71585
What exactly am i checking for?
It seems like the car was lowered but the engine wasn't. It sounds strange...
Old May 12, 2008 | 07:56 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
did you check if bolt was tite enough?
Old May 12, 2008 | 08:16 AM
JMS71585's Avatar
JMS71585
Yes. I did a full walk through of the car, checking all bolts, gaskets, seals, etc. I'm almost positive the rubbing of the strut-bar and plenum is the cause of this vibration, but i never heard of this problem after suspension springs were installed.... Anyone heard of this?
Old May 12, 2008 | 06:45 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
did u check spring sit correctly?
check if springs fit correctly with upper mount
Old May 13, 2008 | 05:46 AM
JMS71585's Avatar
JMS71585
I'll have to check the setup. Its strange because now when i start the car, it starts up normal. And once i put it into drive (5AT), it makes that grinding noise. The noise is there when i accelerate too, but its not so bad anymore. The noise goes away when i let off the gas and just cruise. Very strange...
Old May 13, 2008 | 12:37 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
sounds not from springs, sorry can't help you more without hearing it.
Old May 13, 2008 | 12:49 PM
JMS71585's Avatar
JMS71585
I'm leaning towards the drivetrain now. Seems like the drivetrain is not aligned or is off causing this vibration while in gear. Taking it back to the shop first thing tomorro morning before work. Thanks for your help though...
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
