Brake installation help!
Old Jul 28, 2008 | 12:18 PM
XM 1's Avatar
Default Brake installation help!
hey guys
as some of you know , i bought a stop tech bbk.
know comes the installation...and the first problem ....how to install them i mean one by one or firts front then rear????
how should i raise just the front so that the front wheels are off the ground???(!!safe!! and yes i have a ultra low bodykit ).
any suggestions???
Old Jul 28, 2008 | 12:45 PM
QuicksilverZ33's Avatar
QuicksilverZ33
When I did mine I put the car on 4 jack stands, took all the wheels off, did the install, then bled them...
Old Jul 28, 2008 | 12:47 PM
QuicksilverZ33
If you mean how to put it on jack stands, I lifted one front side, put a stand there, lifted the other front side, so that both front are in the air, then I lifted the rear by the pumpkin and put 2 more under the rear...
Old Jul 28, 2008 | 01:36 PM
terrasmak's Avatar
Just install them however you want, then bleed in the proper order
Old Jul 28, 2008 | 01:45 PM
VO...'s Avatar
VO...
Administrator
+1
I hate to sound mean, but I would think that one who is mechanically inclined enough to tackle a job of this magnitude should already be knowledgable on how to get their car jacked up...
Old Jul 29, 2008 | 10:36 AM
XM 1's Avatar
Originally Posted by vo7848
+1
rofl yeah i know.....i´m kind of sensetive when it comes to jacking up cars ....i saw a couple of times what could go wrong ( and no i didn´t jack up the car )
let´s say i just wanted to know if i could jack up the car just like QuicksilverZ33 did just one front side by the other
Old Jul 29, 2008 | 10:37 AM
XM 1's Avatar
@QuicksilverZ33: oooohhh where did you located the jack stand???since your where using the jack points (i guess) the get the car up
Old Aug 5, 2008 | 10:20 AM
VO...'s Avatar
VO...
Administrator
How did the install go? Updates? Pics?
Old Aug 6, 2008 | 01:01 AM
XM 1's Avatar
installed the rears yesterday was "easy" but i mixed up one of the bridges on the caliper so i´ll have to fix this......just a question!?!?! is it really that hard to get caliper bridge in place???? (on the ST45) in the instruction it seem like "yeah just push it in and you´ll e fine"...?????? but we had to pushed pretty badly to get it aligned.oooooh and one big pro to Stop Tech....3 out of 4 banjo bolts where right....and of course one of them had the wrong diameter AWESOME!!!!!!!!!!!
luky enough i had a couple of blackk anodized laying around (i think i wanted to use them on my race bike but never did).they just fit like a glove lucky me
will install the fronts later today. and ohhh the bleeding is a lot of pain when don´t have a ?bleeding machine?,...had to do it the old school way (i´m little bit consurened about doing so, cause i heard that you could damage your brake master cylinder)
but other then that i´m doing fine....rears look kind a overdone without the fronts
samansharif
Sep 25, 2015 12:31 PM
