lowering spring install problem, cant alight strut.
Old Aug 20, 2008 | 10:26 AM
sbZenth's Avatar
sbZenth
Default lowering spring install problem, cant alight strut.
I finished doing my lowering spring install in the front, but the lower part of the strut tower is not alighned with the control arms.
How can i turn the strut? do i need to recompress the spring and just yank on it? or should the strut tower be able to turn? Is it completely stationary?
Old Aug 20, 2008 | 10:34 AM
sbZenth's Avatar
sbZenth
Old Aug 20, 2008 | 11:16 AM
WTX350Z's Avatar
WTX350Z
Should be able to turn them...having said that, if everything was assembled correctly they should line up. Might recheck the alignment of the spring to perch, and top.
Old Aug 20, 2008 | 04:40 PM
terrasmak's Avatar
Just pop the lower balljoint , once you do that , there is no fighting required.
Old Aug 20, 2008 | 04:51 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
you need to re-clock the strut and upper mount. You might be able to rotate it without removing the spring.
Old Aug 20, 2008 | 04:56 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
its close enough you should be able to "finesse" it into place.
Old Aug 21, 2008 | 07:51 AM
sbZenth's Avatar
sbZenth
im getting some crazy popping, clunking sounds from the driver side.
I need to go through everything and see whats going on. what could be causing it?
i can feel it in the steering wheel when i turn
Old Aug 21, 2008 | 08:01 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
did you finesse it or do it properly?
Remove it from the car, rotate the top mount the proper direction/angle and reinstall. The popping is probably due to binding in the bushing and strut.
Old Aug 21, 2008 | 08:07 AM
sbZenth's Avatar
sbZenth
i did remove it and rotate it to fit it properly. i have a feeling something is still loose. i need to jack it up and see. im going to do that in half hour.
Old Aug 21, 2008 | 10:04 AM
sbZenth's Avatar
sbZenth
fixed. thanks all.
edit:
wtf, why cant i close this thread?
Old Aug 21, 2008 | 10:08 AM
osinrider04's Avatar
osinrider04
bc I'm tryin to buy your lugs that are FS?
Old Aug 21, 2008 | 10:09 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
post the issue and how you fixed it for future reference?
Old Aug 21, 2008 | 10:15 AM
sbZenth's Avatar
sbZenth
Issue:
As you can see in the pictures, the lower connection point on the strut assembly would not be aligned with the control arm.
Fix:
I took the whole strut assembly off. Recompressed the spring on two sides about an inch.
I loosened the strut bolt at the top to the very top of the tread.
I marked the spring and the upper mount with a sharpie for reference.
I took a rubber mallet, and slammed the upper mount a few times in the direction i wanted it to turn.
Retightened everything, decompress the spring. Mount the spring assembly back.
That was the alignment problem.
The popping sound... No idea yet? I loosened and re tightened everything, and made sure everything was in place and it was. Im taking it to steeeze for him to check it later today.
sbZenth's Avatar
sbZenth
oh. oh right. lol.
did you see my answer?
liqalu04
Jan 2, 2022 12:58 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
