Clunking noise...
Old Dec 10, 2008 | 10:17 PM
vbgambini's Avatar
vbgambini
Default Clunking noise...
I installed my Eibach Pro Kit about 2 weeks ago and I started to hear clunking noises in the front when I would maybe pull out of the driveway or at very slow speeds and turning at the same time. When Im driving normal its fine. Some times I hear it sometimes I dont. Any ideas? Im pretty sure I installed it correctly.
Old Dec 11, 2008 | 08:04 AM
vbgambini's Avatar
vbgambini
ok so I should re check the bolts and re tighten them? How tight should they be?
Old Dec 11, 2008 | 09:10 AM
guitman32's Avatar
guitman32
Yes, check and torque to specification in the Factory Service Manual. Some common trouble areas for clunking when removing/reinstalling springs:
Loose upper A arm bolt ("Upper Link" per FSM)
Loose upper Spring seat center bolt (the one that bolts to the top of the shock piston)
Loose sway bar end link bolts
Old Dec 11, 2008 | 09:23 AM
vbgambini's Avatar
vbgambini
cool man ill check those out. any other places i should check?
Old Dec 13, 2008 | 08:09 AM
vbgambini's Avatar
vbgambini
cant seem to find the manual. anyone have the torque specs??
Old Dec 13, 2008 | 08:18 AM
WhiskeyHotel's Avatar
WhiskeyHotel
You can find them here:
http://*********.com/zwiki/Category:Suspension
Scroll down to near the bottom. There's also a TSB on clunking suspension.
Replace the stars with "35Oz-tech" with a zero, not an "O"
Old Dec 13, 2008 | 04:23 PM
vbgambini's Avatar
vbgambini
the link isn't working.....
Old Dec 13, 2008 | 05:07 PM
WhiskeyHotel
Yea, it will if you follow the instructions...you have to edit the link because this wonderful site has phobia about other "Z" websites.
Old Dec 14, 2008 | 10:14 AM
vbgambini's Avatar
vbgambini
o ok. i got it
Old Dec 21, 2008 | 12:48 PM
vbgambini's Avatar
vbgambini
ok. i re tightened the bolts. even took the whole strut back out and adjusted the spring to lock position and I still hear the clunk noise when im turning the wheel at low speeds. I cant seem to find out what it is. any help??
Old Dec 21, 2008 | 12:56 PM
zhuangzi's Avatar
zhuangzi
since it's at a low speed, just ask someone to help you out and listen to exactly where the clunk is coming from
(at least, that's what i would do)
Old Dec 28, 2008 | 07:35 AM
vbgambini's Avatar
vbgambini
i did that and it seems hard to hear it from outside. i dont know
Old Dec 28, 2008 | 01:45 PM
redss's Avatar
redss
with the wheel turned 25 to 30 degree one way or the other, low speed, do you hear one of the front wheel goes clack clack, clunk clunk clack.....?
Old Dec 29, 2008 | 09:26 AM
vbgambini's Avatar
vbgambini
sorta yea mostly clunk clunk. its very subtle. i hear every once in a while. i dont understand. the passenger side center nut under the hood on the strut is tight but the driver side isnt. i cant seem to tighten it. people say use a gun but i did the passenger side with a wrench and rachet. i dont understand why it makes this noise.
Old Dec 29, 2008 | 10:41 AM
JEFFOS69's Avatar
JEFFOS69
I have a bit of the same noise when making a slower tight turn or braking very hard. Its in the front passenger side suspension.
Old Dec 29, 2008 | 04:57 PM
vbgambini's Avatar
vbgambini
mines i think the driver side
Old Dec 29, 2008 | 06:33 PM
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
Would an end link cause this?
Old Dec 29, 2008 | 07:10 PM
SS728's Avatar
SS728
Endlinks.
Normal noise for lowered Z's.
Old Dec 30, 2008 | 09:32 AM
vbgambini's Avatar
vbgambini
so tighten them?
Shift_Speed
Apr 22, 2014 04:53 AM
fernandito7
May 3, 2011 08:51 AM
SuperRobin
Aug 23, 2004 08:25 AM
Dissolved
Dec 29, 2003 07:01 AM
