ebrake lights on!?!
Old Dec 20, 2008 | 01:10 PM
solow350z's Avatar
solow350z
Unhappy ebrake lights on!?!
my ebrake light came on about 3 months ago. when i started my car my ebrake light came on, then ride for awhile, and then it shut off. it did that for a month, now it doesnt shut off now. is it because of my 19in rims or is it just cold. help a fellow Z brother out! thanks....
Old Dec 20, 2008 | 01:48 PM
KornerCarver's Avatar
KornerCarver
You might want to check the fluid level in your master cylinder. I suspect you might be low.
Old Dec 20, 2008 | 04:31 PM
Ruff Z's Avatar
Ruff Z
Your brake fluid is more the likely low, which in return generally means your brake pads are very low.
Old Dec 21, 2008 | 12:26 PM
agentgreen's Avatar
agentgreen
I had this same problem. I researched here, and everyone said brake fluid. So I checked that, and it looked ok. Brakes were squeaking too, so needed to change those out. Once I changed the brake pads, the brake light went off.
Old Dec 21, 2008 | 01:11 PM
QuicksilverZ33's Avatar
QuicksilverZ33
its the pads...had the same prob last yr
Old Dec 22, 2008 | 12:11 AM
solow350z's Avatar
solow350z
Red face
thanks for the info.......i checked my brake fluid, it was ok! but i havent check the pads. its most likely my pads. everytime i wash my car, my front rims always dirty cuz of the brake pads....thanks a bunch!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
