Lowering Springs Picture Thread
Old May 24, 2011 | 11:07 AM
  #301
BSERIEuS's Avatar
BSERIEuS
Originally Posted by FnTrav
Had these Sportlines on the car for several months now and should be settled in. Yes scraping is inevitable but learn your angles! It helps.
f 225/45
r 245/45
what are your camber settings for the front and rear?
Old May 28, 2011 | 11:22 AM
  #302
sry110's Avatar
sry110
2006 Enthusiast on Hotchkis springs. 255/35/19 front, 285/35/19 rear, +22 offset front, +12 offset rear.
I'm finally fed-up enough with the crappy drop on these springs to get coilovers. For example, in this pic I'm parked downhill and the front wheel gap is still bigger than the rear. On more extreme inclines it looks even worse. The spring rates are softer than stock and the thing just wobbles all over the place.
Good riddance Hotchkis!
Old May 28, 2011 | 12:06 PM
  #303
brandon3434's Avatar
brandon3434
^^^You'll see and notice a huge difference! Whats your budget for coilovers? Gonna be lower than that pic?
Old May 28, 2011 | 01:56 PM
  #304
sry110's Avatar
sry110
I was looking to spend around $1200 or less...knowing that this gets me into an entry-level coilover setup. I am strongly considering BC Racing BR series. I want to get the tires just barely tucking, about the same amount front and rear, which I'm thinking will get me back to that slightly raked-forward stance that the car had from the factory (just lower, of course).
What is your coilover setup on the Nismo? I really like the way that turned out.
Old May 28, 2011 | 02:40 PM
  #305
SQBassHead's Avatar
SQBassHead
You should really look into function form coilovers also
Old Jun 30, 2011 | 01:45 PM
  #306
-Trav-'s Avatar
-Trav-
Somewhere around -1.0, but its been a while...
Old Jun 30, 2011 | 02:17 PM
  #307
brandon3434
I would strongly recommend STANCE if you are gonna spend that much. Really, I have driven on some "baller" coilovers and really do think these Stance coilovers are amazing.
Here is what I'm running, check this write-up about my stance's I did...
https://my350z.com/forum/8941779-post28.html
Old Jun 30, 2011 | 04:47 PM
  #308
sry110's Avatar
sry110
Thanks for following up. I ended up buying BC BR coilovers actually, and hoping to get them on the car this Saturday. Out of curiosity what are your wheel and tire specs?
Old Jul 7, 2011 | 12:40 PM
  #309
BSERIEuS's Avatar
BSERIEuS
i couldn't agree more.
i only had my springs for 3 months and got rid of them for some stance coils.
i was saving for wheels and finally decided to go with coils instead. i could not be happier. best purchase i've made for the Z thus far.
Old Jul 7, 2011 | 11:24 PM
  #310
SouthrnComfortZ's Avatar
SouthrnComfortZ
Is anyone on ksport lowering springs? And has anyone heard anything about them? For only 99 shipped and a 1.2 drop all around... I think I might pick them up.
Old Sep 8, 2011 | 12:47 AM
  #311
-Trav-'s Avatar
-Trav-
Sportlines
19x9.5 265/30
19x10.5 295/30
Settled after roughly 50k miles.
Old Sep 8, 2011 | 06:22 AM
  #312
brandon3434
^^^Looks good, love those wheels!
Old Dec 6, 2011 | 11:13 PM
  #313
cb1's Avatar
cb1
NF210 some spacers spring mount shaved a few. 245/35/19F and 275/35/19R
Old Mar 24, 2012 | 03:42 PM
  #314
frostyrock7c's Avatar
frostyrock7c
Originally Posted by -Trav-
Sportlines
19x9.5 265/30
19x10.5 295/30
Are you rolled? Looks great.
Old Mar 24, 2012 | 04:37 PM
  #315
-Trav-'s Avatar
-Trav-
Thank you, yes the rears are rolled to the point of slightly pulling an extra few mm.
Cb1 how much did you take off that spring mount? Thats about as far as im trying to get
Old Mar 25, 2012 | 10:02 AM
  #316
Diabolik350's Avatar
Diabolik350
Tein S Techs, .5 inch cut on spring mounts.
Old Mar 28, 2012 | 01:13 PM
  #317
350zeed's Avatar
350zeed
Originally Posted by jasabeast
youll be fine i ran GF210's and i never got an allignment or camber kit and i had like perfect even wear..
Is there anyone that can second this notion?
Old Mar 28, 2012 | 01:27 PM
  #318
-Trav-'s Avatar
-Trav-
^Always a good idea to at least get an alignment after changing suspension. Id say he was the exception.
Old May 16, 2012 | 12:39 PM
  #319
realist alive's Avatar
realist alive
I have GF210s and you will need an alignment and a front and rear camber kit to get back in to spec. i have the rear camber kit and have not purchased a front camber kit do to cost and my fronts are just barely out of spec Name:  photo36.jpg
Old Jun 6, 2012 | 09:06 PM
  #320
Pbx001's Avatar
Pbx001
Here is the Eibach Pro Kit on a 2004 Touring, just finished the install (no spring bucket mod yet) just standard swap from standard springs. Thought i'd upload this as a reference as I hadn't seen too many of them around
and these will be on next week!
