Lowering Springs Picture Thread
Dec 15, 2012 | 07:21 AM
Tanabe GF210 w/ Rear Springmount Mod & SPC Rear Camber Kit
Dec 15, 2012 | 07:57 PM
My Tanabe GF210 after about 6 months:
Jan 22, 2013 | 11:22 PM
Feb 26, 2013 | 12:13 PM
1.25 Inch drop with spacers?
I've been digging around these forum and the only place I thought I may have a lead was on the sticky but the document is no longer there
I currently have 30mm/rear and 25mm/front on stock 2006 wheels with no issues, however I want to lower 1.25" all around. Does anyone know if this is gonna cause issues with rubbing or camber or anything?
Thanks in advance!
Feb 26, 2013 | 01:07 PM
Super Moderator MY350Z.COM
You will need a rear roll and most likely a rear camber kit
Feb 26, 2013 | 01:21 PM
Hmm, thank you. Does anyone have a pic possibly of a 1.25" drop with spacers? I dug through a lot of old threads and found tons of pics with the drop but not with the spacing (or with stock rims).
Closest I found was user Cheshirecat with the GF210 drop but the picture wasn't really that visible from a corner angle
Feb 26, 2013 | 02:23 PM
Senior Super Moderator MY350Z.COM
Search for Eibach Sportlines.
Feb 26, 2013 | 03:38 PM
Feb 26, 2013 | 05:23 PM
Eibach Pro Kit
TE37 19x9.5 +22 l 19x10.5 +22
RE-11 255/35 l 285/35
* Fenders rolled; has room for 5mm spacers up front and 10mm in the rear
Feb 26, 2013 | 05:32 PM
Nismo S-tune spring+strut
18x10 +26
265/40 Michelin PS1 and 285/40 Toyo T1R
Jun 13, 2013 | 11:38 AM
bumping for accessibility
Jun 14, 2013 | 11:16 AM
updated pics with the rpf1s. tanabe gf210 springs
don't mind the evo
Jun 15, 2013 | 12:04 PM
04 Track on Eibach Pro Kit and 19's
And the alignment afterwards....stock suspension. Close, but not able to get into factory specs after the drop.
Aug 7, 2013 | 04:20 PM
Quote:
Originally Posted by
Bmurray350z
Bmurray, do you remember how much you cut the mounts to achieve that look?
Aug 7, 2013 | 08:01 PM
i just remember cutting like everything i could out... (making everything flat).. hope that makes sense? not really..?
Aug 8, 2013 | 05:34 AM
Ok, got it. It's weird since I've been searching and a lot of people are cutting different sizes.
Aug 8, 2013 | 06:55 AM
Aug 8, 2013 | 01:13 PM
Just be careful when cutting that mount, really easy to overdo it...
Aug 8, 2013 | 02:38 PM
Club Moderator the Hot Spot
I cut a little shy of .5 with tanabe gf210 there was 1 finger gap... close to perfect drop IMO
Aug 28, 2013 | 07:59 AM
350z-Na
Is your Z sitting on 18s or 19s?
