<a href="http://tinypic.com?ref=w1bfqp" target="_blank"><img src="http://i58.tinypic.com/w1bfqp.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com?ref=2rpfk8p" target="_blank"><img src="http://i58.tinypic.com/2rpfk8p.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Any pics of their z using protuninglab springs? with spacers on stock 18s? Their advertising a 1.25" drop and are on sale right now $85!!!!! Spring Rates are F:380lbs R:320lbs
those are probably just rebranded generic springs, same as Megan, Manzo, ksport or other Ebay springs. i would recommend against them, not because they are bad (theyre probably fine if youre just into looks), but because the rear spring rate is way too low to be used with such a drop IMO. hotchkis has a similar rate, but less of a drop, and are linear. these are probably a progressive spring.
honestly, if youre more into the look than into solid handling they would probably do just fine. but if you want performance there are much better choices. just look at any of the pictures that have Tanabe GF, Eibach Sportlines, or Ksport GT springs...they will be a similar drop.
New springs just came in this afternoon, shipping took 1 day lmao from Walnut, CA. As you can see the box says dnamotoring.com
They don't come with instructions and arent labeled front/rear, but I'm hoping the shop I take them to will know more less drop is same front and back so yeah 1.25", we shall see..
Going to install tommorow, keep yall posted on a after pic and alignment img soon
So Im at the mechanic and they just removed my old springs and noticed they're te same in length, wtf?? Called dna motoring and Sarah said they will lower once on the car and fully by two wks.
stock springs were the same length, or the new springs? i swore the rear springs were shorter...or maybe im just forgetful. they are a larger diameter though. eh...staying up late is not good for my memory.
as for being higher than stock, mine was around stock height with the new springs at first. go drive for a bit, give them a few miles...everything should settle down. also make sure that the shop made sure to tighten all the bolts that go through bushings with weight on them. tightening everything down with the suspension at full droop will cause your ride height to be off until the bushings let go from excess stress.
since i didnt have a lift to do this i jacked up the corner of the car until it was compressed and starting to lift off the jackstand (just starting to...i didnt want to get it all the way off, too dangerous IMO). then i torqued all bolts down so they would be at least close when the car was sitting on all four wheels at static ride height.
I was over exadurating maybe same as stock.. I dont know if they put weight on when tightening the bolts, if this is the 'standard' thing to do Im sure they did as he's a fairly reputable mechanic in the area. I drove the car about 10mi today still sits about the same suppose I'll give it a few days. I did notice the quality of the ride was much smoother than before. Now when I hit a bump I don't feel it as much
Just ordered Tanabe GF210's, SPC Rear Camber Arm's and toe bolts. Returning those piece of crap dna's. Quick question.. On the gf210 with stock 17s and 50 series tire, will I rub at all?
Originally Posted by 04SilverBulletZ
Springs are on and car is higher than OEM holy ****
lmfao theyre coming from DNA motoring theyre FOR SURE generic painted springs.
I just brought a 2005 350z. Planning on getting the 350z 18 inch anniversary rim. I am want to lower it for a nice look like a sport lower and still be able to get in and out of my driveway with out effort. What are my option? Can I avoid camber kit? And still in alignment spec. And if I must have camber kit? What is the total cost to order ? I don't want to spend no more than 500.
i just bought the anniversary rims 2 in good condition and two with road rash. I got it for 180. Just had an estimate to repair each rim 65 each. He is coming to repair it tomorrow. Just bought Hotchkis lowering springs for 242 shipped. labor cost for installing the spring is $200 at my trusted mechanic. Will post some picture when it is done.
Reason: Miss text
Asked a few members in our car club, and everyone thinks I'm on drop springs. But as far as I know, I'm not running springs (not original owner). The ones on the car are black, haven't taken them off to see any branding or what-not. How else can I tell if my springs/shocks are worn or I'm running lowering springs?
If it was lowered at all that big gap between the tire and the fender would be non existent.
If you measure from your fender to the top of the wheel... (wheel not tire) the front will be about 4 inches and the back will be about 5 inches on stock suspension.
