Brake squeeking
Old Jun 17, 2009 | 04:43 PM
jimpactmfsc's Avatar
jimpactmfsc
Default Brake squeeking
Hey guys...recently my brakes have begun to squeek...but i only have 12,000 miles on my car can my brakes be going already? it doesnt squeek at all times,only after a while of driving if i press the brake pedal down ..say half way theres a squeek..but if i depress it all the way the squeek goes away. i only hear it after i have been driving for about 30 mins or more every now and then,sounds like it is coming from my rear brakes,any ideas??
Old Jun 17, 2009 | 06:15 PM
PhatZooM's Avatar
PhatZooM
mine have a high pitch squeak too. my pads are kinda low . look and see how much pad you have left
Old Jun 17, 2009 | 06:53 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
The pads aren't low. If they were low, you'd squeak all of the time and it would get louder when you use the brakes. You've more-than-likely just got glaze built up on them. You might try this bedding in process which is usually used when new pads and/or rotors are installed.
http://www.zeckhausen.com/bedding_in_brakes.htm
Old Jun 17, 2009 | 07:14 PM
jimpactmfsc
yea my pads def arent low,i will try the bedding in process and see what happens,thanks!
Old Jun 17, 2009 | 09:44 PM
TreeFiddyZee
Do WHAAAAT!?
You might try some brake cleaner also.
Old Jun 18, 2009 | 09:16 AM
freedonutss's Avatar
freedonutss
Hey jay you gonna go to the mountain run?
Old Jun 18, 2009 | 11:48 AM
GeauxLadyZ's Avatar
GeauxLadyZ
i think another solution to glazed pads is roughing up the rotor a bit.
I dont think bedding will work on glazed over pads, just new pads/rotors.
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
