weird clunking noise in the rear after installing springs
Old Jul 20, 2009 | 03:56 PM
Gizmo0803's Avatar
Gizmo0803
Default weird clunking noise in the rear after installing springs
I just installed some swift springs on the Z, and after driving for a day, there seems to be some weird clunking sound coming from the rear every so often. Does anyone know what it could possibly be? It can't be anything TOO major to fix because installing the rear only required the removal of one bolt. Any help would be greatly appreciated. Thanks!
Old Jul 20, 2009 | 05:45 PM
diablox1's Avatar
diablox1
did u leave your tools in the back of the car?
Old Jul 20, 2009 | 05:54 PM
Gizmo0803's Avatar
Gizmo0803
hahaha nope...never have anything in the trunk.
Old Jul 20, 2009 | 05:59 PM
03brembo's Avatar
03brembo
i think sometimes off brands dont tend to fit perfectly so it may be the spring moving around a bit
Old Jul 20, 2009 | 11:17 PM
Gizmo0803's Avatar
Gizmo0803
does anyone else have this problem? i really don't think it's due to fitment because i paid top dollar for these springs (they cost more than most other springs i think), and i know swift is reputable amongst all suspension companies (even nascar uses them).
Old Jul 21, 2009 | 02:14 PM
beezee's Avatar
beezee
Remember, there is always the possibility of a defective item going through production. Companies try to avoid it but they happen so don't rule that out.
Old Jul 21, 2009 | 03:28 PM
03brembo's Avatar
03brembo
personally ive never heard of swift
who told you they were top of the line?
my buddy installed some cheap knock off springs on his WRX and they clanked around like you are saying
Old Jul 28, 2009 | 09:35 AM
idrive_MD's Avatar
idrive_MD
haha wow, I wouldnt call Swift a cheap brand by any means, their springs are regarded highly as some of the best available. Tuners take springs off of coilover systems like Tein and replace them with Swift units, racers will build custom valved systems with swift springs. Trust me they're top notch.
The noise can be attributed to you not properly tightening something (is the sound isolated to one side or both, does it happen under even loading or uneven loading) or it could possibly be from the slight angle change of the OEM sway bar to endlink relationship which could be causing some of the typical clunking that everyone is experiencing.
If it's the end links, you're only option is to replace them with upgraded ones from companies like SPL, Whiteline or PowerGrid.
Old Jul 29, 2009 | 10:23 AM
Gizmo0803's Avatar
Gizmo0803
thanks for backing me up on the swifts...as far as the problem, i figured it out. i took it apart again and found out that the end of the spring on the bottom wasn't sitting flush with the spring mount on the bottom, and that space where it wasn't sitting flush was where the spring was knocking on. Problem fixed though! If anyone is in the market for some quality lowering springs that are designed specifically around your oem shocks, then pick up some swifts!
Old Jul 29, 2009 | 10:04 PM
SS728's Avatar
SS728
Well good that your fixed your problem. But usually if you install aftermarket springs, your endlinks will make a clunking noise, which is normal.
wanderingstuden
Jan 28, 2016 07:03 PM
seagrasser
Oct 11, 2015 03:27 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
