Shop says "Tension Rods Are Worn Out" ???
Old Oct 17, 2009 | 02:55 PM
terrasmak's Avatar
Originally Posted by dragonfire6
It sounds like I could probably do this on my own... I never had the time to make it to the shop again but this weekend the wheels are coming off and I'm going to inspect the bushings and joints to see specifically what the real problem is... I will post pics to get a second opinion...
I have another question... If my joint/bushings/both need to be replaced, would it be stupid to get an alignment before correcting the problem? Could these faulty parts cause a premature misalignment or do they have no bearing on the camber and toe settings???
From reading and researching it sounds like these parts can cause wear during braking (only???)
Thanks in advance...
Very stupid to try get it aligned , and very shady of a shop to align it if the bushings or balljoints are bad. If it just a boot, who cares, see my post above about swapping the boot out, but i would still wait for an alignment cause you need to unbolt the arm. (in theory it won't affect the alignment , but these cars are funny)
Old Oct 18, 2009 | 02:43 PM
dragonfire6's Avatar
dragonfire6
Default ...
Sooooo I took a look at my compression rods and the bushings appear to be in decent condition however my passenger side ball joint had grease on one side... I think this means I need a new arm, huh?
Old Oct 18, 2009 | 10:01 PM
terrasmak's Avatar
Or just change the boot out while the ball joint is still good.
Old Oct 19, 2009 | 05:54 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Test your ball joint as Davidv suggested and see if you can tell if its bad or not. If not, just do what ^ he said and replace the boot/add alittle grease.
Obadabot
Jun 18, 2023 11:31 PM
ablaine
Nov 29, 2016 10:13 AM
samansharif
Sep 25, 2015 12:31 PM
