Trying to understand brake fluid
Old Nov 11, 2009 | 09:09 AM
redlinedifterzx's Avatar
redlinedifterzx
Default Trying to understand brake fluid
This is my fisrt time doing the brakes on the z Im going with new powerslot rotors hp pads and stoptech steel braided brakes lines. Iv done. Some reading on the whole process of making the install but iv been left blank on a couple of questions I had about the brake fluid.
When it comes to driving my z is a daily driver but I do canyon driving as well as the occasional track and was looking for any recomendations towards the best fluid.
1. Is brake fluid like other parts of the braking system where as if I use a high performance fluid will I not have decent brakes till there heated.
2. Can I use dot 4 as well cause it seems that alot of the hp brake fluid are
mostly dot 4 and the maneul recomends dot 3
Old Nov 11, 2009 | 09:17 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
DOT3 and 4 fluids can be interchanged with no issue. Many new fluids sold these days are not even labelled as one or the other, just as DOT 3 and 4 compatible.
As far as the usage, brake fluid is just hydraulic fluid, designed have as little compressibility as possible to transfer pressure from one location to another as efficiently as possible. The benefit of high heat fluids is their resistance to boiling. When fluid boils, it becomes a gas which is very compressible and the pedal gets soft and spongy until it recondenses back into the uncompressible fluid. There should be no difference in pedal feel from a standard DOT3 or 4 vs a high temp DOT 3 or 4.
If you havent done a bleed in a while, you will probably notice improved pedal feel from getting fresh fluid into the calipers.
Old Nov 11, 2009 | 09:35 AM
redlinedifterzx
Thanx much appreciated and recomendations on a high temp fluid?
Old Nov 11, 2009 | 09:44 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you're on a budget and want a nice all around fluid, ATE Super Blue works great
Motul RBF600 is also popular
if you want something that has even higher temp thresholds and works very consistently on the track, we have the Endless RF600 - expensive, but it's worked amazingly well for us so far!
Old Nov 11, 2009 | 10:46 AM
redlinedifterzx
Any idea on how many bottles of the. Enless 600 I'd need to replace all my fluid?
Old Nov 11, 2009 | 10:50 AM
Z1 Performance
Former Sponsor
depends what you're using to bleed them, but 2 bottles to do the brakes if you're using a power bleeder. If you're bleeding them manually, I'd suggest getting 3
or you can get 3 bottles, and might as well do your clutch at the same time (uses the same fluid)
Old Nov 11, 2009 | 01:16 PM
sektor 11's Avatar
sektor 11
get three....its always nice to have some for track days JUST in case.
Old Nov 11, 2009 | 01:45 PM
DavesZ#3's Avatar
DavesZ#3
Here's a good read on Brake Fluids...
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Old Nov 11, 2009 | 05:45 PM
JETPILOT's Avatar
JETPILOT
There is no way you need Endless fluid. Endless fluid is prohibitevely expensive. It's used in Formula 1 and other competition cars.
Motul RBF 600 is also overkill unless your a really good river and lapping a fast road course (autocross not incuded).
If your doing autocross or short road courses then the ATE will be what you want.
Obadabot
Jun 18, 2023 11:31 PM
burglapfd
Dec 6, 2020 01:04 PM
