Planning to upgrade Rotors and need opinion
Old Mar 3, 2010 | 09:36 PM
krazi3m3's Avatar
krazi3m3
Default Planning to upgrade Rotors and need opinion
I planning to upgrade from my stock rotors and dont want to spend too much i did some searching and got 2 best result in my mind both have mix reviews but all post were 2-3 yrs old. Im hoping to get some more recent reviews from you guys.
these are the two i came upon its between rotorpros and EBC and both about same price
http://www.ajusa.com/details/EBC-Bra...B+3.5L%3B+GAS&
http://www.maperformance.com/rotorpr...-brakekit.html
any advice would be great
Old Mar 3, 2010 | 09:43 PM
terrasmak's Avatar
Well no rotors are really an upgrade unless you go 2 piece, and they don't make 2 piece for non brembo cars. Just get a set of blanks, nothing else is worth the money.
Old Mar 4, 2010 | 01:55 AM
duro78's Avatar
duro78
check out these guys there not as cheap as they once were but still very good.
r1concepts.com
Old Mar 4, 2010 | 02:13 AM
blitz2k1's Avatar
blitz2k1
I went with the EBC ultimax "black dash" rotors they are slotted only. They were lighter then stock rotors and after long aggressive drives I noticed alot less brake fade over the
stock rotors. I am using the EBC "red stuff" pads as well.
Prior to this I was using the OEM rotors with "red stuff" pads....which preformed good but I'm guessing the rotors added alot of fade when things got aggressive.
Old Mar 4, 2010 | 02:46 AM
mw9's Avatar
mw9
+1, if you not upgrading, just stick with blanks. R1concepts.com, can't beat their prices.
Old Mar 4, 2010 | 04:57 AM
vex008's Avatar
vex008
i've contacted a few people with the maperformance rotors and all seem to be happy. some mentioned they didnt like the hawk pads though - think they went with ebc pads.
Was thinking of going with the maperformance but advice from some has suggested it best to get the girodisc 2 pc rotor in the vendor classifieds.
Old Mar 4, 2010 | 05:29 AM
I think you will be happy with either.
Old Mar 4, 2010 | 06:31 AM
huyrua's Avatar
huyrua
https://my350z.com/forum/texas-marke...hawk-pads.html
Old Mar 4, 2010 | 06:39 AM
Brrcats's Avatar
Brrcats
I guess it depends on what youre going for. neither of those will give you an upgrade in stopping power due to the decrease in surface area on the rotor, but will give you an increase in heat dissipation.
So if thats what you're going for then both look fine.
Old Mar 4, 2010 | 08:53 AM
krazi3m3's Avatar
krazi3m3
When you say "blanks" what does that mean exactly sorry for my lack of terms.
Old Mar 4, 2010 | 11:32 AM
terrasmak's Avatar
no slots, drills or dimples
Old Mar 4, 2010 | 01:13 PM
scotts300's Avatar
scotts300
It's likely they're all made by Centric anyway. I'd simply buy "blanks" also (like the ones that come stock) for 50 bucks a piece.
Old Mar 4, 2010 | 03:46 PM
TEF's Avatar
TEF
Like the others above, I concur. Go with the cheaper OEM-style from R1. Have a set for Brembos and they work great.
Old Mar 5, 2010 | 09:56 AM
mcarther101's Avatar
mcarther101
+1 ...no point in upgrading rotors on an OEM brake system... unless it's 2 piece. Save the money for a real brake upgrade later on.
You wont shed any real unsprung weight, nor gain any respectable heat fade-resistance.
OEM 350z brakes are garbage unless they are the Brembo versions fitted with some REALLY aggressive pads & 2 piece rotors.
Old Mar 5, 2010 | 11:41 AM
GeauxLadyZ's Avatar
GeauxLadyZ
R1 Concepts slotted rotors. No real upgrade, but they look alittle better than blanks. I'd def at least get slotted for appearence purposes over blanks.
Function heads are gonna give you the "blanks or nothing" reponses....but for function purposes, they are correct.
The more mass on the rotor = more heat dissapation area = better performing brakes. Only thing you can do to "upgrade" is bigger rotors which require bigger calipers = bbk.
Old Mar 7, 2010 | 09:56 PM
krazi3m3's Avatar
krazi3m3
thx for the inputs imma go with new blanks instead
Old Mar 8, 2010 | 02:22 PM
Max626's Avatar
Max626
i have map rotors with hawk pads, and the two dont mix. Dont get me wrong the performance is way better over stock but not up 2 par for what it should be. If u go with map go with a difference pad stay away from hawk
Old Mar 9, 2010 | 09:58 AM
scotts300's Avatar
scotts300
You have a certain type of Hawk pad, they will not all behave the same way.
_bit
Oct 2, 2015 07:49 AM
samansharif
Sep 25, 2015 12:31 PM
