Spring Question
Old Jun 13, 2010 | 11:25 AM
350@Z's Avatar
350@Z
Default Spring Question
Hey guys im looking into to lowering my Z but I have couple question not sure what brand of spring I want to buy but Im looking for 1 to 1.5 drop. Also if you can chimein with con/pros about buying used springs that were use for the track is this a good idea or not? am looking to spend no more than 250 money is tight right now I have 19x 8.5 and 19x9.5 245 and 275. Thanx I'll apreciate your feedback!
Old Jun 13, 2010 | 11:36 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
at that level of a drop, plan on also buying a rear camber/toe kit as well to correct the rear alignment. Factor in an alignment as well after the springs are installed
Downside of buying used springs are like the downside to buying used anything else...you may not quite know what you're buying. Springs are inexpensive to start with, so unless you can verify all aspects of what you're getting from a trusted seller, it may pay to just buy them new
Old Jun 13, 2010 | 11:48 AM
JasonZ-YA's Avatar
JasonZ-YA
Make sure you read this:
https://my350z.com/forum/brakes-and-...ion-101-a.html
-J
Old Jun 13, 2010 | 01:37 PM
zerostyle's Avatar
zerostyle
i wanted to go as far as i can without getting camber kits or w.e. so i got eibach pros which is one inch all around. with the z once you hit the 1 inch mark you need camber kits. but i took the chance, and my guy at firestone was able to get all my toes and camber within oem...so imo, go with the eibachs
Old Jun 13, 2010 | 03:42 PM
roachbob12's Avatar
roachbob12
I just installed my eibach pro kit about 4 days ago...gotta tell you...super smooth!! not too low or to high! only issue if you are gona put aftermarket rims you will need a camber kit or else you will have weird noises from the tires...NOT SURE IF ONLY ON THE ROADSTER BECAUSE ITS A LITTLE HEAVIER AND IT WILL SIT LOWER DUE TO THE WIEGHT...if your on stocks..youre ok...heres a pic
Attached Thumbnails Spring Question-2010-06-10-13.02.57.jpg   Spring Question-2010-06-10-14.37.07.jpg
Z1 Performance
Former Sponsor
not every car reacts the same to lowering...some will be out of spec when only lowered 1/2 inch, others can deal with more lowering - it all depends on the specs you start off with in the first place
Old Jun 13, 2010 | 07:46 PM
Poor idea. You do not know if the springs have 10,000 or 100,000 miles.
$250 is doable. You will not be able to get anything fancy like progressive springs, But budget springs will suit your needs.
Old Jun 13, 2010 | 09:20 PM
350@Z's Avatar
350@Z
Thanks guys you all were very helpfull I think am going to stay within 1/2 inch to 1 inch at the most. and highly consider Eichbac Pro's. Not looking to gain much performance but just to make the car look more like a tuner rather than look like a monster truck lol
Old Jun 14, 2010 | 06:56 AM
scotts300's Avatar
scotts300
Eibach springs are a 1" drop all around.
Old Jun 14, 2010 | 09:11 AM
Gsedan35's Avatar
Gsedan35
Just posting this to provide information for more informed choices. Just because list it, doesn't mean I recommend it
Oem linear springs
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
Oem linear springs
350Z 2004.5 to 2008 (revised suspension)
Front:314 Rear:427
Nismo Z 2007-2008 oem linear springs front, progressive rear
ride height is the same as other Z models
492/336-672 (initial and final shown for rear springs)
Eibach 350Z progressive springs 1”/1” drop
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2" drop
F: 239/400 R: 257/435
RSR 350Z linear springs .6”/.6” drop (also covers Ti2000 version)
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Cobb Tuning 350Z Linear springs .75"/.9" drop
Spring rates 345/438 (436/535 as shown here http://g35driver.com/forums/brakes-s...new-parts.html )
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2” drop
Spring rates in LBS 358/375
Tokico D-spec 350Z shock & spring package 1"/1.5" drop Kit part# DSK512
Spring rates in LBS 375/375 Linear Springs
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” drop
Spring rates in LBS 314/353
Beware, a 1.2" drop spring is no increase in stiffness vs oem
Swift 350Z linear springs .8”/.6” drop
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2"/1"
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Nismo T2 350Z Linear springs 1”/1” drop
DO NOT RUN THESE WITH OEM SHOCKS OF ANY KIND! TCKline DA's were specifically designed for these springs, however I'd pony up for AST4100's or Anze Engineering Penskes valved accordingly.
Listed for information ONLY!
Spring rates in LBS 690/690
Vogtland 350z progressive springs 1”/1” drop
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Kg/mm springs 350Z
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm springs 350Z
DRacing 30mm drop
Spring rates in LBS initial/final front 252/454 initial/final 252/482 rear
Espelir 350Z progressive springs .4"/.4" drop
Spring rates 386/515 (rear rate IMO is too high for all oem shocks, Z or G)
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Skunk2 350Z progressive springs 1.3”/1”
Spring rate in LBS 238/381 237/395
Old Jun 14, 2010 | 09:17 AM
Gsedan35's Avatar
Gsedan35
As usuall Adam will tell you what you need to hear, not just what you want to hear. 100% correct.
OP, you do have a number of mild drop option's.
Old Jun 14, 2010 | 10:40 AM
angelo350z's Avatar
angelo350z
Oem linear springs
Front:314 Rear:342
Oem linear springs
Front:314 Rear:427
Nismo Z (2007-2008) ride height is the same as other Z models linear front, progressive rear (initial and final rates shown)
492/336-672
Kg/mm springs 350Z
Kg/mm springs 350Z
DRacing 30mm drop
Thanks for this post. It's interesting to see the difference between the Eibach Pro Kit and the Nismo. Glad I went with Eibach.
Old Jun 15, 2010 | 11:28 AM
350@Z's Avatar
350@Z
Thanx G35SEDAN thats great info I think Tein h-tech would do the job am staying within the 1inch drop. i just want to make car look better not looking for much performace gain. Thanx again guys.
issyz
Jul 2, 2017 03:04 PM
