Is there a fix? Brakes click once when pads shift?
Old Oct 21, 2010 | 05:12 PM
newzee's Avatar
newzee
Question Is there a fix? Brakes click once when pads shift?
I've done a search about the single "brake click" that happens when I first hit the brakes after backing up and then moving forward and it explained that it was the brake pad shifting inside the calipers, which is what I thought it might be, but there is no explanation on how to fix it. Is this something that is fixable? I don't remember them making this noise when the car was new. By the way the pads are new.
Old Oct 21, 2010 | 08:38 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
You have a floating caliper and when you go into reverse then forward... they shift. It's common and yea you could change the pad clips but it'll do it again eventually.
Old Oct 22, 2010 | 08:21 AM
newzee's Avatar
newzee
I've talked to some people and they've said that some pads used to come with new clips and a tube of the anti-squeal grease in the box. It's unfortunate that the oem replacement pads from nissan are just the pads only. I'm not sure but I believe the clips are memory metal and I imagine that from all the heat buildup from breaking it will make the metal lose it's memory i.e. spring. I suppose next time I change the pads I'll be sure to get new clips too. Oh well.
Old Oct 22, 2010 | 08:25 AM
newzee's Avatar
newzee
Hahaha! Breaks! Brakes!! My fingers do it right some times, but sometimes they just don't cooperate. Duh.
Old Oct 22, 2010 | 09:40 AM
Flo-ridaZ33
I'm assuming you have Brembo's?
Old Oct 22, 2010 | 10:42 AM
Chris_B's Avatar
Chris_B
The pad clips are made from stainless steel and will wear over time by design. They are sacrificial since they are much cheaper to replace than the cast iron cages, which wouldn't have enough contact surface area anyway.
Chris
Old Oct 22, 2010 | 06:17 PM
newzee's Avatar
newzee
An 06 base, no brembos.
I'll remember to get some clips next time I change my brakes.
It's either a rattle somewhere in the cabin, or a creak, click, or squeak from outside, eh? Love my 350z!
Old Oct 22, 2010 | 10:28 PM
Flo-ridaZ33
I hear the "click" when I go from reverse to a stop.. then to 1st. Lexus 4pot calipers make that sound so its common for me to hear.
Old Oct 27, 2010 | 04:50 AM
agunter33's Avatar
agunter33
I have willwood 6 piston with the same problem! but my pads just slide in and out from the top. Is there a fix? Its so anoying and you can feel it in the peddal. I have to just tap them before using them.....gay
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
