Nismo Hard Rubber Bushings
Old Jan 5, 2011 | 02:58 PM
Row2K's Avatar
Row2K
Default Nismo Hard Rubber Bushings
Does anyone have the nismo hard rubber bushings for the rear or anywhere? Notice a difference, is it worth it? I'd love to go for the rear spl monoball bushings but dont really feel like shelling out 500 on 8 bushings so does anyone have experience with the nismo pieces?
K thx
Old Jan 5, 2011 | 03:05 PM
LaoSiFu's Avatar
LaoSiFu
If I am not mistaken I think they are discontinued. Another option you have are Whitelines and it is what I am running in my vehicle right now.
~Robert
Old Jan 5, 2011 | 04:56 PM
terrasmak's Avatar
Huge difference on a car with a few miles on it, and noticable on a car with lower milage. Basically the stock bushings suck. If you car see's a lot of track, i would get the SPL's.
Old Jan 5, 2011 | 05:02 PM
Kwame's Avatar
Kwame
We are running a few of the NISMO bushings in the front of Adam's car. I don't drive his car all that much to comment on the difference but I'm pretty sure he'll see this thread soon enough and will add any comments he deems necessary.
As far as I know the NISMO bushings are still available.
Old Jan 5, 2011 | 05:09 PM
Row2K's Avatar
Row2K
I didn't find them on your website, but if the rear bushings are available I'll def. pick them up. As far as I know the only other place that stocks them is performance nissan in CA, but UPS shipping kills cross country being that I'm in NJ. Nyways let me know if you have the rear ones, either that or I'll call you guys up tomorrow.
Old Jan 5, 2011 | 07:39 PM
terrasmak's Avatar
Just get the Whiteline ones from Z1!!! From my past experiance with Nismo bushings on my R32 i would have to say Whiteline is better. My Z has a mix of whiteline and SPL bushings.
The difference between SPL and whiteline is also night and day. Slowly swapping to full SPL.
Old Jan 5, 2011 | 07:51 PM
Row2K's Avatar
Row2K
I actually already have whiteline front lower control arm bushings and the SPL compression rod bushings as well as SPL diff bushings.
As much as I would love to go with the whitelines I'm apprehensive about the long term use of urethane and its lack of friction free articulation vs rubber or solid spherical bushings. Just for that reason alone I'll prob eventually replace my front whiteline bushings with SPL units. Long term ill prob go full SPL as well even though they are hella expensive
Old Jan 5, 2011 | 08:17 PM
terrasmak's Avatar
My 88 Ford Ranger has Urethane bushings on the front end that have been there since the lift was installed back in 89. Long term life is really good. Also when properly lubed they are pretty friction free.
Old Jan 5, 2011 | 08:18 PM
JasonZ-YA's Avatar
JasonZ-YA
Front should be like this........
Front:
spl inner at translink - kmember mount
spl compression rod bushing
front upper arms to have solid - ie spl front upper arms
this will yield the front all being able to articulate with out any friction..those are the key pivot points as the spindle points are both ball joints on the two lower arms as well as the upper arm to spindle location.
to save some cash, its acceptable to do whiteline front shock mount bushing, as there isnt a real need for that to be solid.
rear:
going full spl in the rear is nice.....but there are no solids to date for the rear upper control arm..?? so for a main articulation point....having all solids in the rear knuckle leaves room for improvement..
I would run an spl rear knuckle to shock mount as that is the only bushing that does fold over/loose center....
the rear knuckle bushings are small and have very small amounts of rubber..
the only other bushing that should be solid in rear would be the radius rod forward end to eliminate give in that bigger rubber bushing...
if your rear camber and toe arms are not solid's, then whats the point?
ie like spl rear camber arm has a rod end at the subframe lug and either a spl toe arm or spl pro midlink - both with rod ends at the subframe lug..........
all solid pivot points then, but still leaving the factory rear upper arm as oem rubber then the difference is minimal in articulation....improved yes im sure if ALL is done......but a lot for a little.......
your better off spending money in the rear on solid diff bushings and solid subframe to unibody bushings...
-J
Old Jan 5, 2011 | 08:33 PM
terrasmak's Avatar
So Jason??? Want to whip up some Delrin rear upper control arm bushings? I already have whitelines on mine (the move nice and smooth) but solid would be nice. Also they are really really thin rubber.
Old Jan 5, 2011 | 08:56 PM
LaoSiFu's Avatar
LaoSiFu
Sometimes bushings just drive me insane. I always have to go back and see what bushings I have replaced haha and with what brand since I mix and match between Whiteline and SPL.
Yeah Jason I know you can whip up a rear upper control arm bushings. I bet it is on your to do list for this year too
~Robert
Old Jan 6, 2011 | 04:25 AM
JasonZ-YA's Avatar
JasonZ-YA
^ lol...ya whiteline is the only one that makes rear uppers.....the part that saves whiteline bushings is that they have the separate yellow zinc steel sleeve....keeping the bushing from crushing.......so they are definately an improvement at higher articulating points like the rear upper control arm, etc.....but at the spindle points, the oem bushings are fine unless those are the last things you do.......
ya Ive considered making them......machine shop time is what kills.......im a very busy person and would love to make some but just cant see me working on that for a while...
I still have my hydro ebrake bracket in the works along with a bunch of other things...
-J
Old Jan 6, 2011 | 05:02 AM
Kwame's Avatar
Kwame
For a street car the Whiteline or NISMO bushings are great. The SPLs I would suggest for a more track oriented vehicle just as I would any bushing made of Delrin (only for the fact of how much frequent lubrication is needed to keep a Delrin bushing quiet). The SPLs can be used on a street vehicle but they would be beyond overkill and more than likely apt to become noisy after some time.
Old Jan 6, 2011 | 07:25 AM
betamotorsports's Avatar
betamotorsports
Hydlar Z. I make them all the time for various customer cars. Just made the rear leaf spring shackles/sliders for the Rhoades Camaro project. What are the dimensions?
Old Jan 6, 2011 | 07:32 AM
JasonZ-YA's Avatar
JasonZ-YA
^ sweet...anyone have a spare rear upper control arm that they can get some digital calipers on??
I have a spare rear spindle, but no spare upper arm....
-J
Old Jan 19, 2011 | 07:24 PM
tumzilla's Avatar
tumzilla
can worn bushings create a sloppy/loose ride?
Old Jan 19, 2011 | 11:15 PM
tyau's Avatar
tyau
Bushings not so much. A very worn compression bushing might. The sloppiness and looseness happen so gradual that it would be hard for you to notice over time.
The thing with the compression bushing is that they don't wear out easily. But once they start to wear to a condition that you can feel the sloppiness, they start to wear at a highly accelerated rate. Bumpy roads, hard cornering and braking cause major stress on the compression bushings. In extreme cases, a very worn compression bushing can cause front end vibration and brake shimmy.
If you have a very slammed car, the suspension gemometry changes. This causes the bushings to operate at a binding angle. This is where you want to have SPL spherical bushings. The bushings can rotate and pivot smoothly without deflection like rubber or urethanes.
In my opinion, spherical bushings actually improve ride quality very slightly by allowing the suspension components to rotate freely throughout their movements. It also allows the shock absorbers and springs to do most of the shock absorbing work. However, road noise and vibration are the primary byproducts of spherical bearing bushings.
Unfortunately it's hard to make a bushing that has the rotating abilities of spherical bushings, while still absorb vibrations like rubber. I have seen prototypes of bushings that utilize spherical bearings wrapped by a thin layer of rubber. However that proved difficult to produce.
Old Feb 22, 2011 | 11:26 AM
Row2K's Avatar
Row2K
-J
I'm in the process of installing the Nismo rear bushings in those arms. I already did one side but still need to do the other. I'll take a few measurements and pics when I get home today.
I'm getting busy with installing a bunch of rear bushings. So far the list of things being installed/in progress:
Nismo rear upper A-arm bushings (2/side)
Nismo camber arm bushing at knuckle (1/side)
I also already have battleversion camber arms which are solid at the subframe
Nismo radius rod bushing at knuckle (1/side)
Nismo spring bucket bushing at the subframe (1/side)
Nismo shock absorber bushing (1/side) (These sit at the top of the shock and not at the knuckle which I didn't realize, but whateves installed anyway)
SPL shock absorber spherical bushing at the knuckle
SPL spring bucket sperical bushing at the knuckle
Nismo doesn't provide these two to my surprise so I ordered them from Kuah today. They are the exact same size bushing and should get here by the end of the week...I'll take pics prior to install.
All in all I'll have just about every rear bushing replaced with a mix of Nismo and SPL
Old Feb 22, 2011 | 07:10 PM
Row2K's Avatar
Row2K
Here is a pic of one of the Rear Nismo A arm bushing and detailed measurements of it. 4 of these are used and they are all identical.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
nanotech
Oct 2, 2015 05:02 AM
