normal rotors vs drilled/slotted rotors
Old May 26, 2011 | 01:38 AM
Darkness75's Avatar
Darkness75
Default normal rotors vs drilled/slotted rotors
hi
basic normal rotors after some time of use they need to be turned (rotor turning) , can the driller/slotted rotors be turned ?
if yes : dose it need a special machine to do this or the same machine used for normal rotors ?
if no they can`t be turned : would that makes the life of the drilled/slotted rotors shorter than the basic one`s ? or they don`t need to ever ?
and whats better : (longer life,less break pad fade and stopping)
drilled
slotted
drilled/slotted
thank you
Old May 26, 2011 | 03:25 AM
All rotors can be turned.
Old May 26, 2011 | 05:46 AM
Velocity350Z's Avatar
Velocity350Z
^^ Almost everything can be turned...if not, then you turn around it.
Old May 26, 2011 | 09:11 AM
GeauxLadyZ's Avatar
GeauxLadyZ
drilled
slotted
drilled/slotted
thank you
Blank or slotted only.
...brake...
Old May 27, 2011 | 03:08 PM
TheDangerZone's Avatar
TheDangerZone
get blanks....
Old May 28, 2011 | 09:57 PM
Darkness75's Avatar
Darkness75
thank you all ,
i did alot of reading in the net almost every one is saying that the drilled & slotted can`t/should not be turned, and if they did it they will lose the efficiency.
now, i can`t fined dealers who sale blank brembo breaks ???? is that possible
Old May 28, 2011 | 11:32 PM
terrasmak's Avatar
Try searching for Brembo brakes
Old May 28, 2011 | 11:44 PM
MUZZY's Avatar
MUZZY
you can only turn blank or slotted
also there is no performance enhancement if you get blanks, slotted or drilled and slotted, it is just looks
Old May 29, 2011 | 09:20 PM
Darkness75's Avatar
Darkness75
i did !! none ??
do you guys think they stop making thouse ??
Old May 29, 2011 | 09:27 PM
Darkness75's Avatar
Darkness75
will ...... i thought it was for the looks but alot of writings says other wise :
you can read from "Rotor technology" in this site
http://www.carbibles.com/brake_bible.html
p.s: i don`t care much about this though but i just want to show the performance enhancement
Old May 30, 2011 | 02:08 AM
Darkness75's Avatar
Darkness75
found the answer for "what is better" :
http://www.autoaccessorystore.com/Ar...s/Default.aspx
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
