Corner balanced my car
Old Jun 10, 2011 | 05:22 PM
2fasst's Avatar
2fasst
Default Corner balanced my car
I started with pretty bad cross weight 56.5%!
Old Jun 10, 2011 | 05:24 PM
2fasst's Avatar
2fasst
Moved battery into my trunk, lightened some load
On the rack/scales
Attached Thumbnails Corner balanced my car-2011-06-09_15-21-40_195.jpg   Corner balanced my car-2011-06-09_19-04-18_867.jpg
Old Jun 10, 2011 | 05:26 PM
2fasst's Avatar
2fasst
The end result is a lighter and more balanced car. Cross Weight is now 50.0%
Front/rear and Left/right weight biased cannot be dialed out using corner balance, this can only be done by moving static weight.
Handling is now amazing!
Old Jun 10, 2011 | 05:28 PM
2fasst's Avatar
2fasst
This is with me in the vehicle
Attached Thumbnails Corner balanced my car-2011-06-09_19-04-25_79.jpg   Corner balanced my car-final.jpg
Old Jun 10, 2011 | 05:34 PM
03threefiftyz's Avatar
03threefiftyz
Why is your car so heavy...even with you in it...it shouldn't be anywhere near 3600.
Old Jun 10, 2011 | 05:40 PM
2fasst's Avatar
2fasst
My car with my 171 lbs body weight is 3569lbs.
Car alone is is 3396.
I have the Touring model and the motorized/heated seats are pretty heavy. 19" wheels don't help, and about 75lbs of Dynamatt, also a subwoofer, two batteries.
Old Jun 10, 2011 | 05:42 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Ah! Nice does any alignment shop have the ability to do this?
Old Jun 10, 2011 | 05:45 PM
2fasst's Avatar
2fasst
No, they need to have the special scales and you need to have adjustable coil-overs.
I have access to the scales, and I actually did all the work (battery relocating, corner balance) myself. If anyone local wants this done, PM me.
Old Jun 10, 2011 | 05:49 PM
03threefiftyz
I see. I would ditch all that gear if you are interested in getting the car to handle at its peak. My BSP car (touring model), which is limited in what we can remove, is only 3037 and I still have a/c at the moment. Hoping to get it down to 2950 (still full interior).
All you need is a longacre (or other) central unit and (4) pads. I doubt most alignment shops will have them, but any race oriented alignment place will. Depending on where you go...it can be relatively expensive (100-200 bucks on top of the alignment).
Old Jun 10, 2011 | 05:54 PM
2fasst's Avatar
2fasst
Man that is awesome! Would you mind sharing what all you have removed to get down to that weight? Mine is a street car so I have to compromise between performance and comfort. But your numbers are very motivating!
I have no spare tire, no jack, no windshield fluid resevoir, and my Stoptech BBK kit actually lighter than stock, but still way heavier than your vehicle. Please do share
Old Jun 10, 2011 | 06:01 PM
2fasst's Avatar
2fasst
Stock battery compartment/windshield fluid reservoir clear now.
I ran all the electrical lines/fluid tubing to the back in case I decide to install another reservoir back there later.
Old Jun 10, 2011 | 06:07 PM
03threefiftyz
First...I run my car with no fuel (light on). Usually 2-2.5g in the tank.
I have stock cloth non-power seats.
Stock radio is out. No airbag in the steering wheel. 9lb braille battery. Very light exhaust. OSG single clutch (whole assembly with flywheel is ~26lbs to the stock 50 couple pound unit). Stoptechs up front (much lighter). RPF1's with hoosier A6's (10 pounds lighter per wheel/tire combo). Some other various little things.
We are restricted severely in what we can remove. I plan to replace both seats with Ultrashields and ditch the A/C over the winter. That is all I can remove legally.
Old Jun 10, 2011 | 06:28 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Thanks...
Old Jun 10, 2011 | 09:09 PM
winchman's Avatar
winchman
I have ..... about 75lbs of Dynamatt.....
How effective is it in reducing road noise?
Old Jun 11, 2011 | 04:51 PM
SQBassHead's Avatar
SQBassHead
dang!!!! 75lbs of dynamat would equal about 100sq ft!
please post pics of this, not saying your lying..... just want to see if you doubled up anywhere
reducing road noise? YES, very effective (should be) lol
but i bet your car must be solid!!!! please post pics, also what did you cover with the dynomat?
Old Jun 11, 2011 | 05:07 PM
phreaktor's Avatar
phreaktor
Design Engineer
Old Jun 11, 2011 | 05:12 PM
Duckeee's Avatar
Duckeee
wow to weight ratio!
Old Jun 11, 2011 | 06:29 PM
2fasst's Avatar
2fasst
03threefiftyz, thanks for sharing that! Since my car is a street car, i can't go as aggressive as yours. My HKS exhaust is pretty heavy, actually heavier than stock. I may switch for titanium system when the $ permits.
My stock clutch/flywheel surely would have to go! The gain would be exponential, as it's rotating mass!
winchman, SQBasshead, I have Dynamatt xtreme inside the doors, double-layered, in the stock sub location, trunk area, rear sides, underfloor.
Duckee, oh thanks! LOL but it's a street car, so it's a compromise
etkms
Jun 19, 2022 06:30 PM
reno56
Interior
17
Nov 20, 2015 05:21 PM
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
ddegrande21
Sep 6, 2015 11:15 AM
