Tein Monoflex
I just installed Tein monoflex on my Z. Damping setting Front +25 / rear + 20 but i experience some knocking sound at the rear when i go over uneven surface. Even surface no issue. If this normal or something wrong with the coil?
Its normal. (unfortunately) These coils perform good but sound horrible. There's several origins of the noise as well, so theres several fixes that can help minimize the noise. But not eliminate it, in my experience anyway. The bolt hole on the bottom mount was machined too large, needs a washer. Top nut can be a source of noise, as can the pillowball mount. Just search for monoflex rattle and youll find hours of reading and methods to reduce the noise. Good luck.
The fix is easy and cheap and 100% effective.
https://my350z.com/forum/maintenance...e-for-4-a.html
I couldn't find a PVC washer that fit nicely like in the DIY, so I just wrapped the bolt in a couple layers of electrical tape and guided it directly into the center of the bolt hole. Worked great.
Hi I'm from Germany and I'm a tein mono flex. I also have the problem that knocks it back extremely. My coil-over suspension is from the first generation. I was told that I can install the oem camber plates. But it's not Plug and Play. Anyone a description of exactly what to do so that the tapping goes away.
Thank you very much
Thank you very much
