May Need New Rotors
Old Aug 4, 2011 | 12:24 PM
mnkyd21's Avatar
mnkyd21
Question May Need New Rotors
Does anyone know if the Z usually needs all 4 rotors when they're warped? or is it usually front?
Thanks!
Old Aug 4, 2011 | 12:26 PM
KornerCarver's Avatar
KornerCarver
Usually it is just the front rotors that warp. However, if you are putting new pads on all four wheels, I would probably replace all 4 rotors.
Old Aug 4, 2011 | 12:37 PM
nscheuermann's Avatar
nscheuermann
Yeah you might as well go ahead an replace all 4. I know people hate on eBay, but you can get good drilled/slotted rotors on their for a good price.
mnkyd21's Avatar
mnkyd21
Thanks Korner. I think I have newer pads.. but when I stop its vibrating so I'm just assuming I need new rotors. They have been turned already as well. I would rather do two just for money purposes.. and i hope its just fronts!
Old Aug 4, 2011 | 01:32 PM
DavesZ#3's Avatar
DavesZ#3
It depends on if and how bad each rotor is warped. It also depends on the age of the rotors. If one is warped and the other three are at the lower wear limit, it doesn't make sense not to replace the other three as it won't be long before they become too thin and can't be resurfaced.
You didn't say how old the car is and/or how much mileage on the rotors.
Old Aug 4, 2011 | 01:38 PM
bmccann101's Avatar
bmccann101
i agree.
Old Aug 4, 2011 | 01:44 PM
Czarrr's Avatar
Czarrr
Mine vibrates pretty bad too
Debating on wether or not to step it up to used Brembo's or new Akebono's?
OT: Pretty much everything that has been already mentioned is all the advice you need.
Depends on how many miles are on the car.
If one rotor is warped, while the other three are low, might as well do all four rotors.
Usually the fronts are the ones that warp.
Old Aug 4, 2011 | 01:45 PM
mnkyd21's Avatar
mnkyd21
Angry Rotors
Thanks everyone for the insight!
Its an 06' with 107k miles on it!
Old Aug 4, 2011 | 01:48 PM
taywan's Avatar
taywan
ya, id do the drill/slotted for cheap ebay also. they will look good.
Old Aug 4, 2011 | 01:50 PM
mnkyd21's Avatar
mnkyd21
As much as that sounds great, I want OEM rotors and need them asap and driving is getting a little scarey!
Italianjoe1's Avatar
Italianjoe1
Cheap e-bay rotors can be ok, but use a quality pad. Some of the crap that ships with the rotors from vendors online is really poor quality. A rotor is basically a rotor, very few will ever have an issue with anything on the street, but cheapo pads make themselves noticed very quickly.
Old Aug 4, 2011 | 01:52 PM
mnkyd21's Avatar
mnkyd21
Good point! I want oem pads and rotors for sure! I'm going to get it done, I've bought cheaper pads in the past to save money and I haven't liked them!
DavesZ#3's Avatar
DavesZ#3
If they've never been changed - then they are due for replacement.
You can get some good Centric or other name-brand rotors for a pretty good price. I'd stay away from e-bay junk though. Go to autozone, Oreillys, etc. and buy some lifetime replacement rotors and pads.
Old Aug 4, 2011 | 01:54 PM
mnkyd21's Avatar
mnkyd21
That's a great point. A lifetime warranty is definetly something I'll want! Good looking out.
Old Aug 4, 2011 | 01:58 PM
Italianjoe1
I am not a fan of the stock pads, there are much better options out there in the aftermarket. I switched from my oem pads to a higher-end Raybestos replacement at about 5K miles due to the noise from the stock pads cracking, and the braking feel was much improved. Now with some replacement rotors and hawk HPS pads, the car stops like it should have from the factory. (OEM brembos) The compound may be better on the non-brembo cars, just sharing my experience.
Old Aug 4, 2011 | 01:59 PM
Italianjoe1
I'm using the autozone "Duralast" rotors, they are lifetime warranty I believe and were super cheap. Centric makes great stuff as well.
Old Aug 4, 2011 | 02:03 PM
e30cabrio's Avatar
e30cabrio
I have a set of EBC slotted rotors with 10k on them, I paid 600 and will sell all 4 for 300 shipped. (inside the US)
I got G37S Akebonos is the reason I replaced them.
Old Aug 4, 2011 | 03:18 PM
You can check rotors for run-out with a special gage, but the rotor must be removed. If you are going to remove rotors may as well replace them.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
