can i change my coil overs my self?
Old Nov 5, 2011 | 02:42 PM
mr.suavito86's Avatar
mr.suavito86
Default can i change my coil overs my self?
does anyone know if it is diffucult to change the coil overs on an 06 350z?
Old Nov 5, 2011 | 02:46 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Its easy.
If you have to ask....then probably not.
Plenty of information on the forums. Even a diy or two about it.
Old Nov 5, 2011 | 02:52 PM
huyrua's Avatar
huyrua
How mechanically incline are you?
Old Nov 5, 2011 | 02:55 PM
Waiz's Avatar
Waiz
Start here:
https://my350z.com/forum/brakes-and-...ion-101-a.html
Then here:
https://my350z.com/forum/brakes-and-...r-install.html
Old Nov 5, 2011 | 03:34 PM
Duckeee's Avatar
Duckeee
first time is always the most time consuming.
but anyone can do it.
Old Nov 5, 2011 | 03:57 PM
Czarrr's Avatar
Czarrr
It's very time consuming the first time.
I'm mechanically declined but it wasn't that bad.
The removal and install is pretty straight forward.
Old Nov 5, 2011 | 05:39 PM
R350Zz33's Avatar
R350Zz33
me yes you no
Old Nov 5, 2011 | 10:30 PM
SE5spd's Avatar
SE5spd
It's simple
Old Nov 6, 2011 | 12:34 AM
350Zdj's Avatar
350Zdj
You might need an impact wrench. I helped a friend DYI Tein Monoflex and it was pretty easy, except for the super tight bolts that were a PITA to remove. COuld probably take you one full day. The rear set is pretty easy. It's the front ones that is too tedious. Good luck
Old Nov 6, 2011 | 09:46 AM
SuperBlack350z's Avatar
SuperBlack350z
it's pretty damn easy.
Old Nov 6, 2011 | 10:00 AM
suprasam's Avatar
suprasam
This test will help determine if you are worthy...fill in the blanks:
Righty ______, _______ loosey
J/K it's a fun/relatively easy job. Just be careful with the top studs on the rear shock!
Old Nov 7, 2011 | 09:10 AM
AngelsVQ's Avatar
AngelsVQ
rofl
yeah its easy man, just follow one of the diy on here
Old Nov 17, 2011 | 04:50 PM
JeffJohnries's Avatar
JeffJohnries
Using for a Sig for a wheel! Thanks!
Old Nov 18, 2011 | 01:21 PM
BAUSauto's Avatar
BAUSauto
Vendor - Former Vendor
Haha awesome test! But nonetheless there are plenty of info on the forums, seems like a lot of people helped you out! But it can be tedious if it's your first time, but good luck! It's fun for a bit...
- Ben
Old Nov 23, 2011 | 12:55 PM
Z Professional's Avatar
Z Professional
It's not worth paying someone else to do. It's easy if you have the proper tools. If I remember correctly, you can do it all with 3 sockets pretty much..I remember using my 17, 19 and one other..anyway..
Do it yourself, U'll learn alot. Have a friend help you if need be.
Old Nov 23, 2011 | 04:11 PM
terrasmak's Avatar
Simple, if you can do an oil change you can install coilovers. Hardest part is actually setting the ride height.
Up, down , roll car
up , adjust, down, roll car
up, adjust , down roll car
repeat till you get it right.
lapham3
Oct 7, 2022 03:15 PM
