Tokico Gas Shocks??
Old Dec 21, 2003 | 03:11 PM
JasonZ's Avatar
JasonZ
Default Tokico Gas Shocks??
Does anyone know when Tokico is planning on comming out with shocks for the 350Z? I saw some posts a while back about them. I know they had a booth at sema with a 350Z as well. I used to have the adjustable illuminas and they worked great. I believe for the adjustables they were around $450 and non-adjustable called the tokico blues were even cheaper (maybe sub-$300s). I think these would be an affordable alternative to the Konis.
Jason
Old Dec 21, 2003 | 03:44 PM
Red6's Avatar
Red6
A shock just for the 350z should be out soon in january.
My car is the tokico car that you might have seen at SEMA.
The shocks and struts are going to be call the D-SPEC (damping specific) and they are 45 way adjustable.
They use an external ajustment like the illuminas for fine tunning and broader range of rebound and compression.
My car is having the final set put on tommarrow for the LA Auto Show.
I find out the exact price and the date they will be out for ya then.
Paul
Old Dec 21, 2003 | 04:31 PM
jmark's Avatar
jmark
Interesting........
Old Dec 21, 2003 | 06:19 PM
Gsedan35's Avatar
Gsedan35
Oh yeah, real interesting. Hmmm, 45 way adjustable, vs Illumina's 5 way adjustable. Wonder what the extra adjustment range will do to the price?
[edit] found this reference at http://www.tokicogasshocks.com/new.asp
show's the 350Z as a application under developement, timeline is fall/winter 03/04
Old Dec 21, 2003 | 07:12 PM
JasonZ's Avatar
JasonZ
Yea I dont know about the 45 way adjustable. Maybe hes talking about coilovers. I hoping theyll come out with some blues for people who just want to eliminate the bounce.
Jason
Old Dec 21, 2003 | 07:41 PM
jeffrey's Avatar
jeffrey
Jason
If I had to guess, I'd relate it to motorcycle shocks/forks wich also have similar adjustability. He's talking about compression and rebound dampening likely. The "45way) refers to how many clicks (adjustment levels) there are.
Old Dec 22, 2003 | 01:47 AM
TCL's Avatar
TCL
Paul, please let us know how the ride and handling feel after those are installed.
Old Dec 22, 2003 | 02:55 AM
jmark's Avatar
jmark
45 way adjustment!
Old Dec 22, 2003 | 06:09 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
let's just hope it will be similar priced as the Illumina.
Old Dec 22, 2003 | 07:25 AM
dwnshift's Avatar
dwnshift
Can I get an explanation of 45 way adjustable shocks. Counting every click for a rebound or bump adjustment does not count.
Rebound is one adjustment, bump is another, high speed bump is three, high speed rebound would be 4, external cansister preasure would be 5......thats about it. Ride height would maybe be considered 6 but not really....so 45 ways???????
Old Dec 22, 2003 | 08:07 AM
jeffrey's Avatar
jeffrey
Not 45 different KINDS of adjustment...
45 LEVELS. Say rebound "clicks" 20 times, that's 20 different levels of adjustment for rebound dampening.
I could be totally wrong, but he was talking about a remote resvoir as well for easy access (just like the rear shock on my bike) so I'm assuming it's the same thing.
Old Dec 22, 2003 | 09:24 AM
dwnshift's Avatar
dwnshift
The post says "45 way adjustable".....so I was trying to clear that up.
1 way adjustbale shocks usually refers to the shocks having 1 adjustment either bump or rebound.
Another note..... on the Motons we race with...the bump and rebound only have about 8 clicks of adjustment on them.....but one click of adjustment on the Motons makes a huge difference. On most shocks that have 20 or more clicks of adjustment you have to do say 6 clicks to make a noticeable differnece. Its all how they are valved.
Old Dec 22, 2003 | 12:11 PM
Red6's Avatar
Red6
Yes the 45 way refers to compression and rebound dampening. 45 way are the adjustment levels or clicks.
The D-Specs are tuned to work for any race application using HTS technology. They have been in Japan for 3 years and are called the HTS damper there.
They have been used on the fairlady Z33 for the past year and a half in Japan.
If you want more technical info call Tokico Direct at 1-800-548-2549. They can explain the specifics better then I can on the D-Spec Shocks.
Old Dec 22, 2003 | 05:03 PM
JasonZ's Avatar
JasonZ
What about illuminas or blues?
Jason
Old Dec 22, 2003 | 05:37 PM
jmark's Avatar
jmark
Thanks Red6. Any pricing or roll out info?
Old Dec 22, 2003 | 11:00 PM
AmyCroft's Avatar
AmyCroft
Smile Bounce ?
Red6 - Will these shocks remove the bounce in the 350Z or not?
And will they solve the Tire Feathering problem?
Please Reply ASAP
Cheers Amy -
Old Dec 23, 2003 | 01:50 PM
Red6's Avatar
Red6
Default Re: Bounce ?
Please Reply ASAP
Cheers Amy -
The shocks are not boncey like before the car no longer porpoises up and down.
The ride quaility is much improved. Cornering on and off the freeway hard is smooth and the tire seem to hug better. It now rides alot better rail to rail.
Ive have not expereiced the feathering problem with my stock shocks.The D-Specs so far seem fine.
They do not drift to the right but Ive only had them on for the day.
Old Dec 23, 2003 | 01:53 PM
Red6's Avatar
Red6
Jason
They are only coming out with the perfomance D-Spec Shock for the Z.
Old Dec 23, 2003 | 01:54 PM
Red6's Avatar
Red6
No pricing yet. They are supposed to be out sometime in Febuary.
Old Dec 23, 2003 | 03:07 PM
jmark's Avatar
jmark
Thanks Red6.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
