Front & rear camber question
Old Jan 31, 2013 | 04:24 PM
okstate707's Avatar
okstate707
Default Front & rear camber question
Ok, I'm looking to get some camber kits for the front and rear.
I'm looking at the SPL fronts and possible rears, but that's what I have a question about. Can I get the SPL rear camber links (http://thmotorsports.com/spl_pro_sus.../i-521914.aspx) and then get the SPC bolts to adjust the toe? (http://thmotorsports.com/spc_perform...i-397281.aspx)
I only have lowering springs right now so I'm still using the mid links with the bucket holding the springs and don't wanna buy the SPL replacement ones for $700.. I may upgrade to true style coil overs in the future but don't have the money for that right now.
I appreciate the help!
Old Jan 31, 2013 | 07:30 PM
Z_on_TE37's's Avatar
Z_on_TE37's
look at the suspension 101 thread. youll learn a lot and itll answer your question
Old Jan 31, 2013 | 08:06 PM
terrasmak's Avatar
SPC camber arms and toe bolts, then kinetix front arms and your all set.
Old Feb 1, 2013 | 04:29 AM
Lexo350z's Avatar
Lexo350z
If you use a toe arm instead of the toe bolt will you still need the bolt to adjust the toe or can you just adjust toe with the toe arm that replaces the spring bucket???Thanks
Old Feb 1, 2013 | 06:46 AM
terrasmak's Avatar
If you buy a aftermarket toe arm (spring bucket delete , used with true coilover) you will make your toe adjustments from the arm, and you can get rid of the OEM ecentric bolt (a lockout)
All of this is covered in Suspension 101
Old Feb 1, 2013 | 02:53 PM
JasonZ-YA's Avatar
JasonZ-YA
READ THE DAMNN SUSPENSION 101 THREAD!!!!
https://my350z.com/forum/brakes-and-...ion-101-a.html
he.he....
-J
Old Feb 1, 2013 | 03:07 PM
okstate707's Avatar
okstate707
Ok I learned all about the suspension thanks to that sticky! Thanks Jason!
I've decided to go kinetix front and SPC rear. But I'm a lil confused on what all comes in the SPC kit here: http://www.z1motorsports.com/350_g35...oducts_id=4636
I know that's just for one side, but it shows a camber arm and a bolt with eccentric washers on it. Does that bolt with eccentric washers go on the camber arm and I need to buy another pair for the spring bucket for toe? Or do I just use the factory bolt for the arm I'm replacing with the camber arm and the bolt+eccentric washers is for the toe?
Also would it be smart to buy lockout washers to go with the camber arm if those bolts are for the toe adjustment so that the only camber adjustment comes from the arm and not from any slippage from the eccentric washers?
Thanks for the help too guys!
seagrasser
Oct 11, 2015 03:27 PM
hardkicks
Sep 20, 2015 12:28 PM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
