Installation cost?
Old Jul 10, 2013 | 07:50 AM
MB33's Avatar
MB33
Default Installation cost?
Just receive my set of rotors and brake pads front and back. What would be an ideal price for a shop to charge just to install them? Went to midas and quoted me 380 bucks to install front and rear just for new brake pads. I walked.
Old Jul 10, 2013 | 07:51 AM
MantisMan's Avatar
MantisMan
DIY = Free
Old Jul 10, 2013 | 08:26 AM
Bmurray350z's Avatar
Bmurray350z
^ Agree.. brakes are super easy. Just have some pb blaster at hand.
Old Jul 10, 2013 | 09:34 AM
laurentj23's Avatar
laurentj23
Go to DIY section.
Buy some tools!
Spend at least 2 hrs. And it's free!
Old Jul 10, 2013 | 09:50 AM
quakerroatmeal's Avatar
quakerroatmeal
380$ for labor is steep with parts provided.. Find someone local to help you if you aren't comfortable. Like the rest said. Look at the DIY, it's not as bad as you think it is.
Old Jul 10, 2013 | 10:01 AM
Z-Crazy's Avatar
Z-Crazy
If changing wheels is difficulty 1/5, this job would be 2/5
Old Jul 10, 2013 | 12:19 PM
stuartc323's Avatar
stuartc323
bro it takes literally under an hour and half to do this yourself, it will teach you a good life lesson too, and the best part it costs free dollars
Old Jul 10, 2013 | 04:57 PM
travlee's Avatar
travlee
Master
a 22 mm socket with a breaker bar, and i cant remeber the aize of the ones needed for caliper... the hardest part is the ones holding the bracket on
Old Jul 11, 2013 | 09:36 AM
MB33's Avatar
MB33
Thanks for the advice guys. Would I also need an impact screwdriver ?
Old Jul 11, 2013 | 10:10 AM
quakerroatmeal
You do not need an impact screwdriver. The rotors on these cars are free floating rotors. They might be seized on and a little tough to get off at first. The front has a hole where you can put a bolt in and the rotor will pop right off. The rear just make sure your e-brake is off and put a big bar in the back of the rotor to knock it loose or you could use a mallet.
Old Jul 11, 2013 | 01:17 PM
zfamous's Avatar
zfamous
You can probably find youtube videos like people have said. Another thing you can do is post in your regional section and maybe someone can help you out? Either by installing it for you or helping you.
Old Jul 12, 2013 | 04:03 AM
MB33's Avatar
MB33
Great sounds good guys! Yeah saw a couple of YouTube install doesn't look too bad. Hopefully the rotors will go out smoothly. Thanks again!
Old Jul 14, 2013 | 07:45 PM
MB33's Avatar
MB33
Took me four hours to get it done but well worth it.
Old Jul 14, 2013 | 08:09 PM
Bmurray350z
Good job
Old Jul 14, 2013 | 08:10 PM
ZS14RR's Avatar
ZS14RR
Two hours all four corners pads and rotors.
Man up hoe
Old Jul 14, 2013 | 09:02 PM
Z-Crazy's Avatar
Z-Crazy
Thats a good start man
Old Jul 15, 2013 | 05:56 AM
MB33's Avatar
MB33
Thanks for the help!
Old Jul 15, 2013 | 08:18 AM
stuartc323's Avatar
stuartc323
Good job bro, you have gained 100+ man points on your Gold Rewards ManCard, you can use these points towards a well deserved beer.
nanotech
Oct 2, 2015 05:02 AM
