350z Front A-arm Camber arms Hitting. Cleareance ideas?
Old May 20, 2014 | 02:21 PM
albertsZ's Avatar
albertsZ
Default 350z Front A-arm Camber arms Hitting. Cleareance ideas?
I have searched far and wide for as many threads relating to this issue as I possibly find. I have found lots of informative information throughout many threads, but not enough about people actually making adjustments/modifications to the wheel well area for clearance.
So far the two main fixes for this seem to be to either raise the car or cut the area where the a-arm is hitting. I don't plan on raising my car so I plan on doing some cutting to make my a-arms work. I am currently running the SPL v3 front a-arms. Many other popular arms I am seeing are the Cusco, SPC, and KSport.
Here are some photos (taken from another member here) of where the arm first makes contact.
I was planning on doing some cutting in that area, but before I start hacking away I was wondering if anyone has done anything cleaner?
Here is a photo of someone who simply cut out that whole area.. which looks like it works fine but I am worried about the structural integrity of the frame after removing that piece of metal.
And here is another cool idea I want to try that came from an r32... but I don't have access to any type of machine tool or welded so this can be costly. Also on the r32 that area is flat which makes it easy to modify.
Does anyone have any other ideas or pictures of what they have done to give the front a arm some additional clearance they would like to share? I am hoping this thread will shed more light on this issue.
Old May 20, 2014 | 02:24 PM
dcains's Avatar
dcains
Not a chance in hell I'd hack up my car like that.
Old May 20, 2014 | 02:33 PM
albertsZ's Avatar
albertsZ
Totally understandable. Sometimes you take extreme measures to get the results you are looking for... And sometimes there are 'smart' ways to do dumb things...
I know alot of VIP platforms hack away at these upper wells to achieve the low ride height as well.
Here is another photo of an even messier hack job.
Old May 20, 2014 | 02:35 PM
dcains's Avatar
dcains
I never understood any of this. I bought my car to drive. To each his own, though.
Old May 20, 2014 | 02:44 PM
albertsZ's Avatar
albertsZ
Slammed cars can still be very drivable. (with lots of work to correct suspension geometry...) To some people (such as myself) want a nice balance of form and function.
I created this thread to gather some ideas for people who want to go low yet still have enough suspension travel/clearance. I appreciate your input.
Old Sep 15, 2014 | 12:45 PM
albertsZ's Avatar
albertsZ
Just thought that I would share that I went full retard.
End product was worth it. Got some more clearance under load.
Old Sep 15, 2014 | 01:46 PM
cashmoney03's Avatar
cashmoney03
Full retard is correct but alas it is your car and as long as you like it that's all that matters.
Old Sep 15, 2014 | 03:06 PM
tnk210's Avatar
tnk210
You cut your car up for that minimal amount if contact?
Old Sep 16, 2014 | 09:45 PM
AARONHL's Avatar
AARONHL
That is prety geto but I like it
Old Sep 17, 2014 | 06:31 AM
Kileak's Avatar
Kileak
I would look into drilling holes around the cutout and fabricating some type of reinforcement plate with spacers to allow the travel, much like the R32 pictures showed but without actually welding anything.
Even then, that portion of the car is likely not bearing load or flexing but still, just to cover it up. Unless you never drive in the dirt or rain.
Old Sep 17, 2014 | 06:36 AM
travlee's Avatar
travlee
Master
wow, just wow........
Old Sep 17, 2014 | 07:01 AM
Syner's Avatar
Syner
lol
Old Sep 17, 2014 | 07:10 AM
StuLax18's Avatar
StuLax18
General & Tech Moderator
Looks gOOd man. You will be a drift king in no time!
Old Sep 17, 2014 | 07:38 AM
ErkTheJerk73's Avatar
ErkTheJerk73
rimmed up
BH!'s Avatar
BH!
Nice. I have SPLs and PBMs on my car as well and was wondering what overall size wheel and tire you are running up front. Mine is likely smaller at a 235/40/18 on 10.5 -22 but I'm at about your ride height. I only slam arms when I hit dips in the highway but I intend to drift at this height so some cuts may be required. Also, ever re-box the openings or create some type of cover from the elements?
Old Sep 17, 2014 | 12:53 PM
AARONHL's Avatar
AARONHL
Not to mention how easy it is to adjust the camber now. You don't even need to remove the wheel, just adjust it like you have a camber plate on the upper strut mount. Miss that on my Maxima
Old Sep 17, 2014 | 02:40 PM
dj_hype's Avatar
dj_hype
Your car looks fantastic. :drool
Edit: are the faces on your LXZ's polished?
Old Sep 17, 2014 | 05:07 PM
Syner's Avatar
Syner
i just seen the photos. lololol i can't believe you actually did it.
Old Sep 22, 2014 | 10:27 PM
albertsZ's Avatar
albertsZ
thanks homie! the LXZ's are FULL polish so yes the faces are polished
Old Sep 22, 2014 | 11:52 PM
KingBaby's Avatar
KingBaby
Hardest Setting
This pinch weld is very dangerous and hopefully you cut or beat it to one side...
With a fat tire setup it cut my tires
If anything you could of cut on side then reweld it to sit a tad higer
emooheo
Oct 14, 2015 08:58 AM
hardkicks
Sep 20, 2015 12:28 PM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
