Spring like noise when braking
Old Sep 9, 2019 | 09:25 AM
RawrXTC's Avatar
RawrXTC
Default Spring like noise when braking
I've been trying to fix this problem for sometime now with no luck. I've searched and found that a few others have had this issue but none posted a solution.
When I'm braking at low speeds I hear a spring-like noise like if a spring was bring stretched and plucked (it literally sounds like 'boing boing'). That only happens when I'm coming to a slow stop. The speed doesn't matter. I could be going 60mph and brake and not hear it but as soon as i get down to about 10mph or so it starts happening.
I have taken apart the brakes and cleaned/greased everything that needs to be. The pads are new and I just recently changed the rotors hoping that was the problem since my old ones were pretty much done for. The pads were changed about a year ago with no issues. The problem started about 4 months ago then it went away for a week then came back and is staying.
If anyone knows what's going on and how to fix it I would greatly appreciate it if you share your knowledge.
Old Sep 9, 2019 | 01:21 PM
travlee's Avatar
travlee
Master
So you didnt get an answer from the same post at 1038 this morning, so you posted it again??. Some people work
https://my350z.com/forum/2003-2009-n...l#post11001894
Old Sep 9, 2019 | 11:35 PM
813_350Z's Avatar
813_350Z
And then to not even acknowledge the reply on his other post. Posts question twice in 3 hours, takes at least 14 to respond.
Old Sep 10, 2019 | 12:12 AM
terrasmak's Avatar
Post a video if possible
Old Sep 10, 2019 | 07:12 AM
RawrXTC's Avatar
RawrXTC
I posted it in two different areas. I didn't know that wasn't allowed. I posted it in the general 350z section first then I figured I should probably post it in the tech area as well. My mistake.
I didn't see a response to my other post and it appears to be gone now...
I'll try to get a video, but I'm not sure if the noise will come up on the video or not.
Thanks for the replies.
Old Sep 10, 2019 | 02:47 PM
Spike100's Avatar
Spike100
It would be very helpful (and pushing towards an answer/solution if you can post a video with sound.
Old Sep 18, 2019 | 03:46 PM
RawrXTC's Avatar
RawrXTC
Alright, sorry it took a little while to get the video.
Here is the link to it. You can hear the spring noise a few times and that happens 90% of the time when I'm coming to a stop around 15 MPH to 0 MPH. If I brake hard then nothing happens it's only when I'm gradually stopping.
Old Sep 26, 2019 | 02:57 PM
RawrXTC's Avatar
RawrXTC
Anyone know what the cause might be?
Old Sep 27, 2019 | 12:31 AM
terrasmak's Avatar
That sounds like the ABS pump actuating
Old Sep 27, 2019 | 06:44 AM
RawrXTC's Avatar
RawrXTC
I was thinking it’s the ABS as well. Any idea what might be causing it?
Old Oct 1, 2019 | 09:43 AM
terrasmak's Avatar
Does your car have TCS or VDC ? What tires are on it, front and rear. Have you ever removed the steering wheel ? You have different possible issues
Old Jun 24, 2021 | 01:26 AM
Mike Ribeiro's Avatar
Mike Ribeiro
Did the OP ever figure this out? I'm having the EXACT sound under the exact circumstances. I just had my lower control arms replaced and this immediately started happening once I left the shop
Please help. Sick of reading everyone with the same issues and then no one ever posts the solution in the thread and everyone stops replying.
Old Jun 25, 2021 | 03:46 PM
Mike Ribeiro
Fixed. Improperly seated wheel sensor. Mechanic who did my control arms must have done something to not seat it correctly
AtomicX
Jul 20, 2012 11:34 AM
joe3228
May 10, 2010 07:30 PM
Rekinyze
Jan 15, 2010 04:59 AM
Octogoogles
Aug 11, 2008 01:00 PM
