Hit curb need help
My 350z recently met a curb while drifting going roughly 15-20 at an angle. Ive already ordered my lower control arm with the ball joint, the upper arm and new coil assemblies for the front but just wanna know if anything else looks bad.
There's no way to know how many parts were damaged from a few photos. But that looks like a huge hit, and you should probably find an alignment shop to work with and have a tech give you a list of parts to be replaced before you get a new four-wheel alignment. Don't forget to replace the wheel and tire as well.
Upper arm is likely fine, but I would get the rear lower arm and knuckle as well as, or instead of the upper, it’s called tension arm/compression rod. As well I’m sure your hub/bearing took a good part of that hit, and may be bad currently or will develop a noise later.
SoCali-Z
Nov 20, 2015 06:07 PM
