STOPTECH wheel clearance
Old Mar 21, 2004 | 03:53 PM
dollar99's Avatar
dollar99
Default STOPTECH wheel clearance
If you have the 14" Stoptech brakes, please list the wheels and offsets you are running. Also, please note if you have front/rear or both.
Old Mar 21, 2004 | 04:17 PM
Eagle1's Avatar
Eagle1
For the track, Nismo 18", with 8.5"front and 9.5" rear, on Toyo RA-1 tires. 245/40/F and 275/35R.(equal 25.3" diameter F and R).
For the street, Enkei (A&L Racing) Saruwatari 19", with 8.5" F and 9.5"R, .25 offset, on SO-3 tires (245/35F and 275/35R)
StopTech 14.1" rotors and four piston calipers all around.
Hope that helps.
Old Mar 24, 2004 | 01:48 PM
Mo350Zart's Avatar
Mo350Zart
Stoptech Front 14" & Stock RAYS 18" whells...
Any clearance problem?
Old Mar 25, 2004 | 05:50 AM
ether's Avatar
ether
HREs 547s
F:8.5x19 +18 R:9.5x19 +18
Michelin Pilot Sports F:245/35/19 R:275/35/19
Stoptech 14" F+R
Old May 15, 2004 | 06:27 PM
ether's Avatar
ether
adding one more to the database.. just test fitted them, the Prodrive GC-05F 18x8.5 +23 will clear both front and rear 14" stoptechs
Old May 16, 2004 | 06:16 AM
MY350Z.COM's Avatar
i believe stoptech's website has a template you can make to see how much clearance you have.
Old May 16, 2004 | 11:19 PM
dollar99's Avatar
dollar99
AXIS Milano's with +15/+20 offsets clear the stoptechs just fine.
Old May 16, 2004 | 11:25 PM
ether's Avatar
ether
18's or 19's? and widths
Old May 17, 2004 | 12:43 PM
Chebosto's Avatar
Chebosto
14.1" all four wheels WILL clear stock Track Rays no problem
they will also clear 19x8.5, 9.5, 10.5 Rays TE37 +22 offset..
Old Jul 9, 2004 | 07:43 PM
ether's Avatar
ether
here of some pics mounted
Old Jul 9, 2004 | 07:47 PM
ether's Avatar
ether
fronts
Old Jul 9, 2004 | 07:48 PM
ether's Avatar
ether
rears
Old Jul 9, 2004 | 09:15 PM
MY350Z.COM's Avatar
such a nice car.
Old Nov 24, 2004 | 07:07 AM
King Tut's Avatar
King Tut
Figured I would update this:
14" Front and Rear Stoptechs will clear
19x8.5 +23 Volk GT-7 Front
19x9.5 +24 Volk GT-7 Rear (barely)
Old Nov 24, 2004 | 10:35 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Some GTC / GT7's will fit... some of them do not because they have lower caliper clearnace for bigger brakes or not... with this in mind... you could order the same offset as someone else but get a wheel that is not a high pad wheel...
Here is a link to the wheel fitment chart page for stop tech which we are an authorized dealer for...
http://www.stoptech.com/wheelfitchart/nissan.htm
Old Nov 24, 2004 | 12:25 PM
ZxRage's Avatar
ZxRage
Almost the same setup here.
14" all the way around and will clear 9.5" +12 front and 10.5" +22 rear on Volk LE37s.
Obadabot
Jun 18, 2023 11:31 PM
