koni or tein
Old Jun 10, 2004 | 11:31 PM
denic79's Avatar
denic79
Default koni or tein
I'm debateing wether I should go with the tein basic dampner or just and koni shocks to my eibach setup. Can anybody give me some suggestions on what to do. I just want to get rid of the bounce and it doesn't handle as good as I want it too. What are the best sway bars to go with? I was thinking cusco!
Old Jun 11, 2004 | 12:14 AM
themartyr's Avatar
themartyr
I hae no clue about the shocks but you have a good height going with those eibachs. What size wheels and any rubbage?
Old Jun 11, 2004 | 12:27 AM
denic79's Avatar
denic79
The height is great, but the ride is s***. I have 19x9 on the front and 19x10.5 in the rear with 245/35/19 front and 285/30/19 rear.
Old Jun 11, 2004 | 12:44 AM
themartyr's Avatar
themartyr
Looks great! I ll be getting sway bars but that doesn't affect the smoothness of the ride does it?
Old Jun 11, 2004 | 12:58 AM
wutafobb's Avatar
wutafobb
tein basic..eibach is too soft, plus basic is coilover so it will match better than just random springs with koni.
Old Jun 11, 2004 | 02:20 AM
mac's Avatar
mac
TEIN MAN ARE YOU NUTTS
Old Jun 11, 2004 | 05:27 AM
SangWL's Avatar
SangWL
just out of curiousity where in MA are you at. It seems your either in the north shore or south shore.
sang
Old Jun 11, 2004 | 06:56 AM
speedform's Avatar
speedform
Hotchkis (sp.) bars are pretty good. Their adjustable and hollow to keep the weight down.
Old Jun 11, 2004 | 09:32 AM
Phatmitzu's Avatar
Phatmitzu
Tein. No doubt.
Old Jun 11, 2004 | 09:43 AM
HanZolo's Avatar
HanZolo
Koni's are adjustable which allows you to match the dampening with the spring rate. Stiffer isn't always better.
Old Jun 11, 2004 | 09:47 AM
leemik's Avatar
leemik
denic79, haha I recognize those pics from the Z meet down the cape.. I just got a set of Tein basics yesterday (not installed yet) and have hotchkis sways coming (good luck to me gettin' them )..
I hate the bounce too and I have a serious pull to the right problem that the dealer can't seem to fix...tire feathering?... I only have 3.5K miles on my car so time will tell...I'm hopeing the new setup will kick ***.. fingers crossed
You are welcome to take a ride in my car at the next meet
--mike
Old Jun 11, 2004 | 12:31 PM
Gsedan35's Avatar
Gsedan35
Tein Basics offer 60% greater stiffness with dampners that are matched to them. And the vast majority of lowering springs for the car are not truely in the performance realm being progressive so they can work with the oem dampners, which also explains why they offer up about a 23% maximim increase in spring rates over stock rates. koni's for this platform use less compression dampning then oem, not a compromise I care for. They are also single adjustable for rebound (rate of return), so you can't get back the compression dampning Koni took out. The Koni's will have a limitation on how much spring rate you can increase and still work effectively with the rebound turned up. It is most always a lower figure then Koni Quote's as the max poundage. No matter what it is likely that the Koni's offer better valving control then oem on oem springs. But my past experience is, rebound only adjustability does not yield great results when upping spring rates over oem. I could see the Koni's to a point, but less compression dampning and single only adjustability crossed them off my list before they even went into production.
On Tein Basic dampners, their preset dampner valving is the same as a Tein SS coilover set to 8 out of 16 adjustment levels (btw, Tein SS coilovers will be out for these cars soon).
Another thing to consider is that the Basics do offer more spring stiffness over oem. Oem spring rates are 314/342
Tein Basic (HKS Hypermax II use's same spring rates)
Front:504 Rear:504 F+61% R+43%
Transfers +18% to front
Old Jun 11, 2004 | 01:56 PM
lawnmore's Avatar
lawnmore
Default Soften it up
You seem to have done a lot of homework,maybe you can shed some light on my problem. I have an 04 touring and I would like to improve the street ride. Do not track and don't want to lower,just smooth out the ride.I have talked to the people at Tein, they suggest High Tech or Type CS. Any thoughts?
Old Jun 15, 2004 | 02:39 AM
jreiter's Avatar
jreiter
Default Re: koni or tein
Perhaps your tire sizes are contributing to your handling problems. (?) I see you are running a 40mm narrower tire up front than in back. That's a big difference and is surely contributing to understeer... if that's what you are experiencing. The stock 18" rims have a 20mm diff. If you are experiencing understeer, then you might want to consider narrower rear tires or widers front to help even out the difference. A lot of serious track guys have run the same width all the way around and say it's the best option for handling.
Old Jun 22, 2004 | 04:49 PM
denic79's Avatar
denic79
So whats the verdict on the tein basic, is it worth the money and how much of a difference is it. I'm so sick of the bounce, it is absolutly driveing me crazy.
Old Jun 22, 2004 | 06:32 PM
Grey Matter's Avatar
Grey Matter
I have the Tein Basic and like them very much. Was going to get springs and then shocks later, but went with the Basics instead. Only had to pay for one install rather then two, they are designed to work together (springs and shocks), are height adjustable, and rebuildable if required. They take care of the bounce and make the ride much more controlled. For the money they are good deal IMO.
Old Jun 22, 2004 | 08:09 PM
350Mark's Avatar
350Mark
Ok... On my other car (Lexus IS300) I have the Tein Flex coilover installed. With the softest setting (16f/16r) it was pretty much smooth just like factory. When I changed the dampening to say (2f/2r), the ride stiffened up. I would get crazy bounce, especially on the highway. Now with the Z, It is definetly stiffer in stock form than my IS. So i'm assuming thats the reason for the bounce.
From what i've read, the Tein Comfort Spec will "soften" up the ride dramatically making it smoother. Will this get rid of the bounce or am I just stupid? Obviously you will lose handling for comfort. Decisions...Decisions...
Bodyboarder81
Nov 2, 2015 12:17 AM
uro279
Jul 1, 2003 06:15 AM
failsafe
Apr 23, 2003 11:38 AM
MannishBoy
Jan 21, 2003 10:39 PM
