Bugs Bugs Bugs
Old Jun 12, 2005 | 06:24 PM
RSXPLAYA's Avatar
RSXPLAYA
Default Bugs Bugs Bugs
So i was preparing my car for wax, but I am having trouble getting the Bug residue off of my car!. I can get most of the mass off, but there is small white hazes everywhere!. I tried using turtlewax bug remover, it helped, but i cant get everything off. Now i have alot of rub marks on my paint for how hard ive been trying to get it off!. Help!
Will
Old Jun 12, 2005 | 07:07 PM
DavesZ#3's Avatar
DavesZ#3
Chances are it's because the paint/clearcoat has been etched by the acids in the bug-guts. If you don't wash bugs off shortly after you get them, then you will wind up with permanent etching.
If you've introduced scratching or hazing to the paint, you're going to have to use something like 3M Swirl Mark Remover to polish it out. If the etching is bad enough, you might need to compound it first then the SMR.
Old Jun 12, 2005 | 07:37 PM
RSXPLAYA's Avatar
RSXPLAYA
Thanks for the reply. im gonna try washing the front again and pick up some remover. I think there is still a layer of soemthing, cause i can feel the paint rise when i move my finger over it.
Old Jun 12, 2005 | 07:40 PM
zand02max's Avatar
zand02max
try washing real well, then claybarring, that should do the trick. Or try bug/tar remover. Then re-wash!
Old Jun 12, 2005 | 08:28 PM
pacfwu's Avatar
pacfwu
use degreaser. the bug guts are wet and any exhaust residue from traffic infront of you will adhere to it and make a glaze that hardens. the degreaser will breakdown the exhaust residue and the bugs will come off very easily.
my dad drives long haul and has a black truck. I know all sorts of tricks.
Old Jun 12, 2005 | 10:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would still try claybar before degreaser...
Old Jun 13, 2005 | 07:23 AM
RSXPLAYA's Avatar
RSXPLAYA
wouldnt degreaser eat through the paint??. Im going to get the claybar and try that out
Old Jun 13, 2005 | 09:08 AM
mrZeee's Avatar
mrZeee
if you can feel it in the paint...you may have etched the paint...you may need to polish that out...megs dacp comes to mind...
Old Jun 13, 2005 | 02:36 PM
JamRWS6's Avatar
JamRWS6
Degreaser is too harsh for a fine finish. Simple soap and water shortly after the bugs have landed is the safest and most effective way to remove them. If you have let the bugs sit for a while the finish is toast anyways.
Old Jun 13, 2005 | 05:58 PM
Kevin Overall's Avatar
Kevin Overall
Try a clay bar........
Old Jun 13, 2005 | 06:59 PM
RSXPLAYA's Avatar
RSXPLAYA
THanks for the help guys. I washed it again and used the clay bar. I think i used too much of the spray at times but the bugs really erased right off. Thanks again
Will
Old Jun 17, 2005 | 03:43 PM
JETPILOT's Avatar
JETPILOT
Simple Green removes bugs, and residue when used full stregnth. I am in the bug capital of the world. FLORIDA. You would not believe the bugs I get on th front of my car. I spray some SG on the front bumper, and wash the car as usual. They come right off.
Respect (for Simple Green)
JET
Old Jun 17, 2005 | 07:09 PM
JamRWS6's Avatar
JamRWS6
JET
Simple Green is a little strong for paint IMO.
SEK Z
Cleaning & Detailing
Jun 15, 2003 05:15 PM
The Brickyard Rat
May 23, 2003 04:25 PM
ZpEeDRaCeR
Apr 8, 2003 09:34 AM
darkalley
Mar 23, 2003 05:02 PM
