Zaino detailing...
Old Feb 23, 2003 | 07:51 PM
JZC's Avatar
JZC
Default Zaino detailing...
Can you Zaino a car in sections?
Like, the hood one night, side panels the next, ect?
I have very little time to do a whole car so I'm going to hit it in sections. Is this alright to do?
Old Feb 23, 2003 | 10:07 PM
afr0puff's Avatar
afr0puff
Yes and no. If you are adding ZFX to the Zaino, then you must use all of it within 6 hours for optimum results. You will also have to throw away the remaining ZFX enabled zaino and the bottle if you go above 12 hours.
If you aren't using ZFX, then you can do whatever you want.
Old Feb 24, 2003 | 05:16 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I agree with the above but why would you want to do this? To apply the Zaino (Z-2 or Z-5) to the entire car takes like 10-15 mins. If you have the ZFX in it, it cures in less than an hour (MUCH less if it is fairly warm and dry outside). To take it off takes about 15-20 mins.
I would think you'd have enough time to do the whole car. You may want to consider doing the whole car with say, Z-5 then the next day (if you don't drive it in the meantime) do another layer of Z-5 or go to the Z-2.
Old Feb 26, 2003 | 01:13 PM
Kevin V's Avatar
Kevin V
If you are just trying to build up protection or fill in swirls there is no problem doing an area at a time when time is limited, I do it, but with that scenerio there really isn't any point in wasting the ZFX, just use the Z-2 or Z5 without the additive.
mcduck
Cleaning & Detailing
Nov 9, 2002 11:30 PM
MacGuru
Oct 19, 2002 03:04 PM
Dr Bonz
Oct 11, 2002 01:32 PM
z461
Oct 6, 2002 07:33 PM
