Zaino ZFX ruined!
Old Mar 30, 2007 | 07:34 AM
RedLeader's Avatar
RedLeader
Default Zaino ZFX ruined!
ZFX is priced like liquid gold, so I use it sparingly. I carefully sealed the little ZFX container and stored it in one of the applicator bottles when I put it away. When I pulled it out last weekend, it was harder than a rock. WTF? Anybody else had this problem?
Old Mar 30, 2007 | 07:40 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
damn, that sucks. I thought you were going to say it ruined your paint.
I never really give it much thought, but i just put the lid on and never had any issues.
Old Mar 31, 2007 | 03:59 PM
usarmyttt's Avatar
usarmyttt
yes, call Sal, he will probably send you some out.
Old Mar 31, 2007 | 04:02 PM
plumpzz's Avatar
plumpzz
If you want to know a little secret, if you wax in the sun, you'll never noticed you never used it.
Old Mar 31, 2007 | 05:47 PM
mthreat's Avatar
mthreat
I couldn't understand that statement -- are you saying, if you wax in the sun, it won't look like you waxed at all? In other words, you're suggesting to wax in the shade? Just checking.. you said 'never' twice and messed up my english parser
Old Mar 31, 2007 | 06:28 PM
SargentZ's Avatar
SargentZ
+1 that made about no sense.
Old Mar 31, 2007 | 07:08 PM
hndumafia's Avatar
hndumafia
i'm pretty sure he means that applying zaino in the sun will make it cure fast enough that you don't need to use the zfx. i generally apply in the sun since i don't have a garage or car port, but still use the zfx for good measure to make sure it's all broken down properly before removing it.
Old Apr 1, 2007 | 05:16 PM
RedLeader's Avatar
RedLeader
I used the ZFX because I was trying to follow Bonz directions to the "T". I know our humidity in Oregon isn't anything like the SouthEast, but I wanted to get the best results possible.
Old Apr 1, 2007 | 05:45 PM
plumpzz's Avatar
plumpzz
SOrry I ment if you use zaino waxes in the sun you won't need ZFX. I havnt used it in a whole year. It actually cures at the same rate.
Old May 12, 2007 | 07:55 AM
350Zenophile's Avatar
350Zenophile
From the application instructions:
When you are finished polishing, wash the mixing bottle inside and out with a heavy concentration of liquid dishwashing detergent or even better Isopropyl Alcohol and thoroughly rinse. The ZFX™ mixing bottles cannot be reused if the polish remains in the bottle for more than 12 hours. After 12 hours, it is not possible to remove the ZFX™ accelerator from the mixing bottles. Throw the mixing bottle and any unused polish contents away after 12 hours.
Maybe it got contaminated?
Old May 12, 2007 | 08:09 AM
DavesZ#3's Avatar
DavesZ#3
OP never indicated how long between uses. That stuff does have a shelf life.
It might have been stored some place hot/cold/humid or exposed to other chemicals.
The cap or bottle might have had a crack and it dried out.
Old May 12, 2007 | 08:59 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
whats the shelf life? crap i got bottles of this stuff everywhere.
Old May 12, 2007 | 09:08 AM
skidmarq's Avatar
skidmarq
Bruce, ZFX is not necessary IMO. If you perform the waxing in the sun, you can let the wax cure for a few hours and get the same results from my tests...
Old May 12, 2007 | 09:10 AM
ARMSTRONGARMS
zfx is necessary for the first application from what i got from sal? after the intial 1st coat, then it's not.
Old May 12, 2007 | 09:13 AM
skidmarq's Avatar
skidmarq
I dunno, all it is supposed to do is speed up the curing cycle from the documentation I've read...I tried it and didn't notice any benefits, but that is just my opinion.
Old May 12, 2007 | 09:16 AM
DavesZ#3's Avatar
DavesZ#3
From the Zaino FAQ (http://www.zainostore.com/Merchant2/...=Z#anchor37124)
Q: What is the usable shelf life of Zaino products?
A: A 70° room temperature is best for the longevity of Zaino products. Due to the optical additives used, extreme heat or cold can result in a decrease in gloss-enhancing properties.
When stored at average room temperature between 65° and 75° degrees, shelf life is as follows:
Z-PC 3+ years
Z-AIO 3+ years
Z-CS 5+ years
Z-1 For optimum results, use before 3 years.
Z-2 For optimum results, use before 3 years.
Z-3 For optimum results, use before 3 years.
Z-5 For optimum results, use before 3 years.
Z-6 5+ years
Z-7 5+ years
Z-8 5+ years
Z-9 5+ years
Z-10 For optimum results, use before 2 years.
Z-12 For optimum results, use before 2 years.
Z-14 For optimum results, use before 2 years.
Z-16 3 to 5 years
Z-18 5 years +
ZFX For optimum results, keep tightly capped, avoiding moisture. Use before 24 months.
Katie93
Sep 15, 2015 05:57 PM
sean2168
Cleaning & Detailing
183
Mar 22, 2003 05:36 PM
MacGuru
Oct 19, 2002 03:04 PM
Mikey Likes It
Sep 25, 2002 04:52 AM
