dirty plenum, want it clean....
Old May 3, 2007 | 08:19 AM
Cam350's Avatar
Cam350
Default dirty plenum, want it clean....
My plenum on the engine has got all these rough blotches all over it and it looks a pretty ugly, and i want them off. I dont know if the car came from a place near the ocean and the salt air did something to it or what, but its not a clean plenum, i would like to get it looking right again.. Any suggestions, i want to get it looking like sort of a glossy finish, or would that require putting a whole new plenum on?
If you want me to post pictures of it when i get home if your a little puzzled on what im talking about, just let me know. Thanks for your help!
Old May 3, 2007 | 08:49 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
yes post pics? the factory plenum is a dull grey rough cast aluminum. It is not at all glossy from the factory
Old May 3, 2007 | 08:50 AM
ARMSTRONGARMS
oem one w/a not quite finished polished version
Old May 3, 2007 | 08:55 AM
Cam350's Avatar
Cam350
yea mines like the bottom one, but it has all these ugly blotches on it, I ve tried getting them off, but i cant. thanks for the help though, and did you polish that one yourself, or buy it polished? If so where at?
Old May 3, 2007 | 12:48 PM
Cam350's Avatar
Cam350
guys, i need some answers to how to get this thing clean, please help me out here
Old May 3, 2007 | 03:30 PM
I just scrub it with soap and water. 36,000 miles above.
Old May 3, 2007 | 05:03 PM
Cam350's Avatar
Cam350
Default added some new pics to my plenum which i think is dirty.. may not be. you tell me..
heres what mine looks like... in some areas, you will see the sort of smoothish texture then if you look on down near the strut bar and all around you will see what i'm talking about, the blotchyness... and who knows, i may be wrong... mabey the smooth parts are the bad things, but typically on anything smooth is better.. correct me if i'm wrong.
other than the plenum [which may not be even dirty since this is my first Z and it may be a rookie mistake on thinkin it is dirty when its not (i'm pretty sure it is) ] the engine bay is otherwise clean..
if it is dirty, from what you all see, just let me know the proper cleaning techniques..Thanks a lot
Old May 4, 2007 | 04:04 PM
This is more than simple dirt. Looks like corrosion. Cleaning will not help. Consider painting the upper plenum.
Old May 4, 2007 | 04:06 PM
Cam350's Avatar
Cam350
Yea see i thought it was corrosion, ok so if i wanted to paint it are you saying like a color or like a primer?? and the corrosion wont affect the engine will it?
Old May 4, 2007 | 04:10 PM
Auto parts store carries suitable paint: engine block, callipers, headers. All will work.
Old May 4, 2007 | 04:16 PM
Cam350's Avatar
Cam350
ok good, well what type of paint would you consider using?
Old May 6, 2007 | 01:02 AM
ARMSTRONGARMS
if you can spare the downtime, i would get it powder coated.
Old May 6, 2007 | 12:00 PM
Cam350's Avatar
Cam350
Ahh, idk if i could wait but ill keep that in mind
Old May 10, 2007 | 01:52 PM
VO...'s Avatar
VO...
Administrator
+1
Old Jan 31, 2009 | 01:45 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
+1 As long as you're not spilling crap onto the plenum, it should stay fairly clean. I would take the whole thing off and scrub it down and dry it, then let it sit overnight for good measure before putting it back on. Be sure you cover the lower collector with a clean towel or tee while the car sits.
I just took off my powdercoated Crawford plenum and need to clean it. I'm letting it air dry outside before bringing it in to scrub it down. Reason for removal? I'm getting it polished. Not too keen on the blue powdercoat anymore.
liqalu04
Jan 2, 2022 12:58 PM
allmycarsdie
May 13, 2016 04:38 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
