Zaino Issue...Help!
Ok I purchased the total protection car kit yesterday and I started to follow the directions and I was on the step where you apply z-5 polish to the car. I was just finishing the first coat of it and the clouds rolled in and it started to rain. I obviously couldnt finish it and I had to leave it on there with the light haze on the car.
My question is how should i go about finishing it or should I just claybar it next time and redo it.
Any help would be appreciated.
Originally Posted by New JerZ
so basically just clay the car and start over then? Also on another note can I reuse the 2 terry cloth sponge things that came with the kit?
You can leave Z5 on for 24 hours before buffing off. You should be fine... Like said above just use a bit of Z6 if it is a bit stubborn... I like spraying Z6 on a MF towel and wiping then use a seperate towel to dry and buff instead of spraying directly on the car.
