Best leather conditioners...recommendations please?
Old Nov 28, 2007 | 03:48 PM
skn5002's Avatar
skn5002
Default Best leather conditioners...recommendations please?
On the side of my drivers seat, the leather is beginning to show cracks. Are there any good leather conditioners out there that will prevent the cracks from getting worse?
Old Nov 28, 2007 | 03:56 PM
usmanasif's Avatar
usmanasif
Poorboy's 'Leather Stuff' has worked great for me over the past 1.5 years that I've had the car.
Old Nov 28, 2007 | 04:00 PM
SuperBlack350z's Avatar
SuperBlack350z
Lexol Cleaner and conditioner (two separate bottles)
Old Nov 28, 2007 | 08:05 PM
1cleanz's Avatar
1cleanz
zanio works very well to plus it makes the leater smell like leather. very strong leather smell though.
Old Nov 28, 2007 | 08:29 PM
SeannMikee's Avatar
SeannMikee
I use meguires, its works awsome.
Old Nov 28, 2007 | 09:36 PM
MustGoFastR's Avatar
MustGoFastR
Zaino Leather in a Bottle FTW.
Old Nov 28, 2007 | 11:43 PM
1sickveilsidez's Avatar
1sickveilsidez
I used to use lotion believe it or not and worked great, one a month and I would wipe it down with a damp cloth in between to keep it looking good. I find that some of those leather products are kind of harsh on the seats.
Old Nov 28, 2007 | 11:55 PM
SuperBlack350z
using lotion is not good for the seats. Some contain high volumes of oil that we are trying to take off the seats that causes discoloration. You'll find out the hard way down the road.
Old Nov 29, 2007 | 12:47 AM
1sickveilsidez
Yeah well i've had the seats upholstered 3 times already so I haven't really noticed anything wrong. Plus i'm too lazy now to even do that, I just wipe it down and go, thanks for the info on that though, now I know. I just figured hell if it's good for your skin it has to be good for the seats?
Old Nov 29, 2007 | 06:29 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
My favorite combination of products is the Leatherique Prestine Clean and Rejuvenator Oil. This is a powerful cleaning and conditioning formula that can help soften and strengthen your leather. The Poorboy's World Leather Stuff is also pretty good, but doesn't condition quite as deep in my experience.
To help prevent more wear and tear I suggest you read this article I wrote as well.
The Other Kind of Leather Care
No one likes to see their leather fade, crack or stretch, yet this is an extremely common problem. As most people are aware, good leather care involves a regular routine of cleaning and conditioning. Cleaning your leather helps remove contaminates that become embedded in the leather and clog the leather’s pores. Conditioning helps replace proteins and other natural properties that can fade over time due to normal usage, UV rays, etc. These basic steps are essential elements to good leather care but there are other ways to care for your leather that are just as important.
The driver’s side bolster, or the part of the driver’s seat closest to where the driver enters and exits the vehicle, often shows the most wear and tear. This area is prone to stretching and cracking due in large part to the method by which the driver enters and exits the vehicle. Often times while entering the vehicle you will sit down on the edge closest to the door and slide into the middle of the seat. While this method is natural to most people, there are two basic problems with this technique. Most seats are slightly concave with the lowest point being in the middle of seat. Therefore when you sit on the edge you force the leather to flatten, which stretches and flexes the leather, especially on the outer edge. If you repeatedly stretch and flex the leather you may prematurely start to add permanent creases, cracks and stretch marks to the leather. The second problem is when you slide and twist your body to move from the outer edge to the middle of the seat. Your body’s downward force will generate plenty of friction to start to slowly wear away the top layer of your leather. This can lead to your leather looking worn and faded and this damage is generally permanent. These same exact problems happen in reverse when you’re exiting the vehicle. Most people twist and slide their body towards the outer edge of the seat and then exit the vehicle. To help prevent these kinds of problems try and reduce how much you slide and twist in your seat. Instead lift straight up and down when entering and exiting the vehicle. This simple step can be a tremendous help towards preserving your leather.
One step that should be apart of everybody’s routine is protecting your leather. Ultra Violet rays from the sun can dry out and fade your leather. Heat helps opens the pores of your leather, which allows proteins and other nourishing elements to evaporate more readily. Without these properties leather becomes less flexible which can lead to fading, cracking and stretch marks. After you have cleaned and conditioned your leather you can protect your leather with a product like the 303 Aerospace Protectant. Lightly mist the protectant on a microfiber towel outside of your vehicle, to avoid overspray, and wipe down the seats. Make sure you regularly protect areas that have prolonged exposure to the sun. A good protectant will also make it easier to remove contaminates and oils during future cleanings.
Here are some other areas of concern that you should be aware of to help care for your leather. Be careful that your seatbelt does not regularly rub against the leather. Always use safety first, but adjust the belt accordingly if it’s potentially damaging the leather. Be careful of what you and others wear in your vehicle. Some articles of clothing and jewelry can be sharp or blunt like buttons, rivets, and zippers that can potentially scratch or otherwise harm your leather. Human oils, lotions, make-up and contaminates that are commonly found on the human skin can prematurely dry leather. Avoid touching your leather excessively and wipe down any areas that regularly come in contact with human skin.
Try and observe any other habits you may have that may be harmful to your leather, and see what you can do to minimize them. Follow the tips listed above and regularly clean and condition your leather and you’ll have leather that always looks great.
Let me know if you have any other questions.
Greg @ Detailed Image
Old Nov 29, 2007 | 08:28 AM
jmark's Avatar
jmark
That's what I've been using.
Old Dec 9, 2007 | 09:07 AM
sloughdawg's Avatar
sloughdawg
3-4 years ago 3M had some cleaner/protectant that was awesome it came in a couple scents and the one I used had a yellow cap and black bottle. Does anyone know where to find some of this. Made car smell great. I could not find it on 3M site
Old Dec 9, 2007 | 02:03 PM
Spork's Avatar
Spork
I use Armor All Leather Care
Old Dec 9, 2007 | 02:08 PM
Get_Zwole's Avatar
Get_Zwole
couldnt have said it better
NiLL
Nov 29, 2021 02:26 PM
seagrasser
Oct 11, 2015 03:27 PM
