Drag NHRA, IDRC, IHRA, NDRA
12s NA
Old Nov 22, 2005 | 06:55 AM
  #81
95snoozer's Avatar
95snoozer
Originally Posted by 1QUICK1
I've seen it many times. The difference is not so much a 60FT variance but whether or not you're spinning significantly off the line.
A 2.1~ more often than not has some good spin, getting it down to a 1.9 more often than not removes a good deal of spinning. Generally if you spin off the line you end up seeing slightly inflated trap MPH.
the worse my 60 foots, the worse my trap. such has always been the case.
on a hard launch on slicks my 1/8th mile mph always drops but the 1/4 is higher
i run 12 psi on slicks and 14 on nittos
Old Nov 22, 2005 | 08:04 AM
  #82
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by DayBlueZ
No, i'm not. Weaving does increase trap. But, it lowers time also.
If you are weaving, you are increasing the amount of time on the track and the length. Therefor, you increase the trap.
I don't think that weaving and the inherent increase in friction and drag would make the extra few feet that you add to the 1/4 mile give you any trap speed. The directional changes alone would bleed off speed.
Have you tried this??? It doesn't sound like something any reasonably intelligent person would do from a pure safety standpoint.
Old Nov 22, 2005 | 08:35 AM
  #83
DayBlueZ's Avatar
DayBlueZ
no, it wasn't done on purpose. On our track we have a pipe burried that is for run off. Where they covered it it left a white line. Kind of like a side line on the street. I used to move over to follow it before i realized i was sort of weaving. The time keeper pointed it out to me when he saw my traps rise that i must be weaving. If you deviate at all from a straight path, it will cause a small rise.
Old Nov 22, 2005 | 02:44 PM
  #84
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
That is wierd.....
Zike
Sep 21, 2007 07:19 PM
MyZFiona
Dec 1, 2006 12:12 PM
05 NISMO
Jul 29, 2005 02:44 PM
BriGuyMax
Drag
49
May 7, 2005 01:36 PM
