My best slip from SDR, lastnight......
Originally Posted by Alberto
if shorter gearing would cause you to go into 5th, then it would def drop your trap.
What's the top speed for 4th on the non-revups? 108? 112? I can't remember.
Let's just say it's 112. Then say hes running a tire that drops that max speed to 108. So if he's shifting to 5th, he's trapping AT LEAST 108. That's a nice jump from 105
PS. don't take this post seriously
I don't get out of 4th, even with the smaller diameter tires.
The same rpms make for less speed.
I tell you what, next time I go to Steele, I will run both again, and video document the outcome. With our gearing through 4th, the optimum tire diameter seems to be around the stock size, and it does make a difference in your trap speed at the end.
Originally Posted by VeeTec
It does lower your trap speed due to gearing.
The M/T's were 26.0 when they were brand new, and have worn down to about 25.7. My Firestone WO's were 26.3 brand new, and are now about 26.2.
If you correct for tire diamater, even that little amount makes a noticable difference.
I would have trapped close to 106 with the street tires on.
http://www.moddedmustangs.com/perfor...culators/#tire
better gearing does not reduce mph, infact it will increase it if you are crossing closer to redline
thats a bs rule of thumb that isnt true.
lower tire pressure, i.e. bigger contact patch, i.e more rolling resistance reduces mph
12 psi on slicks CAN hurt the 2nd 1/8th mph, but depending on how much you spin on street tires going to a slick can even increase your 1/4 mph because you are putting down a higher average power throughout the race.
"Its science"
you didnt lose 3 mphg going to DRs, thats bull****
I trap the same radials, DR, slicks, I just et better on each. Its called being consistant. Slicks might hurt me by .5 mph at 12 psi
We need to go to Steele soon. I went once a few weeks ago and ran a new best, can't wait to run in this cooler weather.
"Its science"
"Its science"
Gearing does make a difference. I had a Maxima that would run better if you shifted early out of 3rd into 4th, where as the shift point for 1st-2nd and 2nd to 3rd was redline. That fact became a common drag strip practice among 4th gen Maxima owners. If you left in in 3rd, your trap would be lower, and you would drop out of the peak power band too long. There are a lot of factors, and it does vary between cars, but with the Z I have seen for myself what the difference is. I run 32 lbs with the DR's, and I am aware of what rolling resistance is. Consistency is not an issue with my driving either.
BTW, I would appreciate level headed discussion, this is not the street racing forum. If you disagree, that is your right, and I am always open to opinions, as long as they aren't expressed as profanities and personal attacks.
I don't plan on doing one single mod, until I reach a 12.9, probably during cooler weather. I was happy that I ran 13.2 with so so track prep, so I think it will come later this fall.
Let me know when you are going a couple of weeks out, so I can plan ahead. By the time I hit a 12.9, you should be running 12.7 or so!
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
