Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Apr 22, 2010 | 09:27 AM
  #2181
jblz's Avatar
jblz
a bit more, huh? an 11 sec sedan is something to be proud of...keep us posted
Old Apr 22, 2010 | 09:34 AM
  #2182
03threefiftyz's Avatar
03threefiftyz
Auto have a valve body and/or stall?
Old Apr 22, 2010 | 10:28 AM
  #2183
MardiGrasMax's Avatar
MardiGrasMax
Yes, VB and ProTorque, full mod list below
2006 G35 Sport Sedan,
5 Speed automatic
Liquid Platinum color
Factory navigation
Satellite radio
Built and tuned by myself
Engine Modifications:
Weisco Pistons, 020 over, 8.8:1 Cr
Eagle rods
ARP head and main studs
Rotating assembly balanced
S1 Cams, JWT clones
Greddy twin turbo kit, 18g turbos
Tial Lg Yellow 10psi waste gate springs
SFR dual intercooler kit for G35 bumper
Greddy Type RS blow off valve
Turbo XS UTEC
Turbo XS Tuner Wideband
Blitz SBCid Color boost controller and systems monitor
Boost gauge
Oil pressure gauge
Oil temperature gauge
AFR gauge
Fuel pressure gauge
DW 650cc @3bar Injectors
Walbro GSS352 fuel pump
Custom return fuel system
CJM return correction kit
Fuel feed line upgraded to 3/8” hard line
NISMO thermostat
PermaCool oil cooler
MotoDyne 5/16 intake spacer
K&N air filters
NGK IX 2 step colder plugs
Redline 10w40 motor oil
Redline Water Wetter
Drivetrain:
ProTorque torque convertor
Upgraded valve body
B&M transmission fluid cooler
B&M external transmission filter
Redline D4 ATF
Redline 75W90 differential fluid
Exhaust:
2.5” test pipes
Megan Y pipe
Custom 3” electronic exhaust cut out
Stock rear section
Suspension and Wheels:
2006 350z springs & struts
Volk GT7 19x8.5 front, 19.9.5 rear
Hankook Ventus S1 255x35-19 front tires
Toyo R888 295/30-19 rear tires
Cloaking Assistance:
Belltronics STi Driver detector
Laser Park Pro laser jammer
Future Wants:
Upgraded brake rotors and pads
Front camber arms
Finish building my spare trans with Alto packs
Old Apr 22, 2010 | 04:10 PM
  #2184
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by MardiGrasMax
1. 2006 G35 Sedan
2. Auto
3. Street Toyo R888 DOT Steel Belted ( drive with these everyday, over 15k so far)
4. Greddy TT
5. No Juice
6. Built
Hit the revlimiter in 3rd, but still a good time!
Nice pass Matt! Way to get her out of the hole on street tires. SOOOO close to 11s...
Old Apr 24, 2010 | 08:38 AM
  #2185
ajcool2's Avatar
ajcool2
Nicce Mardi! Almost as fast as your maxima was. Im sure we'll be seeing 11's soon.
Old Apr 25, 2010 | 04:12 AM
  #2186
NightShade's Avatar
NightShade
25. 209Z33 ----------------------03 Tour 6spd 13.494@104.56mph 2.068 60ft Street
Thanks for catching that.
Hey, you guys haven't updated my time yet. I'm at 13.52 now! Woohooo!
04-04-2010 04:18 PM
NightShade I'm happy, hit my goal for a stock car. Well, aside from the tires...
Old Apr 29, 2010 | 06:45 AM
  #2187
Romanteni's Avatar
Romanteni
whoah thats sick
Old Apr 29, 2010 | 02:39 PM
  #2188
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
04-04-2010 04:18 PM
Sorry for the delayed response. I thought I replied to you, but apparently, I didn't. Anyway, your time has not been added to the list because your posted ET is slower than the 25th spot's ET. And thanks to your non-OEM tires, you don't qualify for 100% stock category.
Old Apr 29, 2010 | 02:40 PM
  #2189
03threefiftyz
Chris, he is an HR.
Old Apr 29, 2010 | 02:55 PM
  #2190
3hree5ive0ero
Retired Admin
Wow, again? I apologize for my mistake. I just updated the list with your new time. Sorry about that. I've been working a crap ton of hours with around 3-5 hours of sleep each night and I guess it affects me more than I thought. Thanks for catching that, Mike.
21. NightShade ---------------------08 Base 6spd 13.722@102.78mph 2.021 60ft Verifeid Street
Updated with
16. NightShade ---------------------08 Base 6spd 13.528@105.24mph 2.004 60ft Verifeid Street
Old Apr 29, 2010 | 03:50 PM
  #2191
MardiGrasMax
Could you update the twin turbo listings with my run in post 2176 please. Slip is posted.
Old Apr 29, 2010 | 10:12 PM
  #2192
3hree5ive0ero
Retired Admin
22. MardiGrasMax ----06 Auto G35 -----------Built Greddy TT 12.041@113.41mph 1.827 60ft Street
Bumping off..
25. Priscilla LS1 ---04 6spd Enth ------------- Built PE TT 12.357@110.62mph 1.903 60ft Slicks
Old May 6, 2010 | 08:00 PM
  #2193
ChuckD05's Avatar
ChuckD05
This is my slip from a 09 370z 6 Speed Manual with bolt ons on M/T ET streets that I got from aceman... Time could of been better but the radial slicks mixed with oem front tires made the car unstable and I def didn't push it to its potential.
I was asked by a member to post here but I don't see a 370z section... so sorry for posting if this is not my area to post in!
Old May 6, 2010 | 09:26 PM
  #2194
ajcool2's Avatar
ajcool2
Nice time. What do you mean when you say the car was "unstable"? Im pretty sure there are alot of Z's running stock tires up front with faster times. What did your other times that day look like?
Also what did you race against? It looks like if the driver knew what they were doing it might have been a pretty good race.
Old May 6, 2010 | 09:42 PM
  #2195
03threefiftyz
Its not uncommon to have an unstable sway to the car when you have bias ply's in the back with stock radials up front. Since it was his first pass with that set-up I would guess the "floating" feeling was unsettling. Most just get used to it, but if he wishes to move to another option more power to 'em, but the bias ply will be faster and a little easier on driveline parts.
Old May 6, 2010 | 09:53 PM
  #2196
fowlman01's Avatar
fowlman01
If a person has not run on Drag Radials before, it is not uncommon for them to think the car feels unstable.
Old May 6, 2010 | 10:00 PM
  #2197
03threefiftyz
^he was on bias ply ET streets.......My MT DR's had no sway what so ever and I ran them on the street to and from the track without issue.
Old May 6, 2010 | 10:13 PM
  #2198
fowlman01's Avatar
fowlman01
Maybe it is just me and the people I hear talk about how DR's feel. They feel funny to me above 80mph.
Old May 6, 2010 | 10:17 PM
  #2199
03threefiftyz
Some of that is pressure dependent....at 14ish psi they get a little "floaty" but nothing extraordinary to me.....or even really all that noticeable. Could just be that I was so accustomed to it. With 28psi in them they felt just fine though.
Old May 6, 2010 | 10:22 PM
  #2200
fowlman01's Avatar
fowlman01
I think it is a matter of how often you drive on them. I don't use the DR's that much and when I do I drive to the track with 32# in them. I get the wobbly feeling when I run at the track at 18# or so. It is not a big deal, just a different feeling. I figure if guys are doing 160+ on them I should be able to keep it in a straight line at 106 or so.
