Drag NHRA, IDRC, IHRA, NDRA
03 350Z Base 1/4 @ firebird
Old Nov 6, 2007 | 06:57 PM
  #41
speedsniper's Avatar
speedsniper
On all of the runs I didn't really launch, just eased off the clutch and onto the throttle simultaneously at about 1,000 rpm. Last time I was at the track I dumped the clutch and spun all of first gear.
Old Nov 17, 2007 | 08:13 PM
  #42
tornatic!!'s Avatar
tornatic!!
Originally Posted by speedsniper
14.094 @101.46mph, 60' 2.242, 1/8 9.197
14.373 @100.43mph, 60' 2.465, 1/8 9.461
14.139 @100.98mph, 60' 2.254, 1/8 9.219
14.060 @99.88mph, 60' 2.347, 1/8 9.156
14.444 @98.41mph, 60' 2.284, 1/8 9.841 (let off in 3rd)
Not bad but your car has so much more potential. On that 14.0 run if you drop that 2.2 to a 2.0 60 ft you'd have a possible 13.6 run.
Old Nov 20, 2007 | 12:27 PM
  #43
oro's Avatar
oro
His times aren't bad at all, for those of you in the know about AZ, we just don't put out good times unless you are heavily done up, I went to the track a couple weeks ago as well with my gf in the car.
RT: .373
60Ft: 2.185
330: 6.042
1/8: 9.189
MPH: 78.52
1000: 11.893
1/4: 14.163
MPH: 98.90
That is the best time I could pull out of the night, I was on stock tires, test pipes, and headers, as well as the clutch/flywheel.
For a frame of reference most of the GTO's/LS1's at firebird that aren't slicked out or heavily done up are usually putting down low 14's, I only saw an M6 GTO break into 13.9 my first time since I started going to the track when I went to firebird, as well as an E46 M3 pull out his all time best of 13.8.
Hence the reason I was more than impressed seeing Hal put out a 1/4 at speedworld, mind you most tubbed out slicked drag racing muscle cars out there are barely in the 10's if that.
Old Nov 20, 2007 | 05:00 PM
  #44
Skorch's Avatar
Skorch
Hey oro, I tried calling you when I went to Speedworld back in October but you never picked up... You going again anytime soon?
Old Nov 20, 2007 | 05:51 PM
  #45
Peak350's Avatar
Peak350
If you work on your launch a lot, your 1/8th will fall dramatically, lowering your ET. Its not the backhalf thats killing your times (making it in ~4.8 seconds, thats about the same as I am (13.2-8.5 = 4.7ish). I trap the 1/8th a bit higher, a lot of things could cause that, but your car is running fine, just work on shifting faster 1-2 and 2-3, and get out of the hole .1-.2 quicker and you'll be well into the 13's. Great times considering the location.
Old Nov 24, 2007 | 05:49 PM
  #46
oro's Avatar
oro
I probably will be soon, want to see what she can do with the gears now but gotta get a lot of stuff straightened out before I can get back out there, I also think I may be consuming, so I just need to get some time to check her out.
Old Nov 26, 2007 | 02:49 PM
  #47
one350zfan's Avatar
one350zfan
Thanks for all the comments, i want to get in to the 13's with out doing anymore mods, so ill try lowering the tire pressure and launching around 2500rpms.
I ran a 13.9 @ 101 2.1 60' in 98 degree heat with similar mods in an 03 base about a year and half ago. Its a good starting point, but definitely work on the tire pressure. Tires are the most important thing besides weight, so look into buying a set of cheap used DR's and you'll find yourself well into the 13's
Workshop12
Mar 23, 2020 01:45 PM
WillyP28
Oct 12, 2015 04:24 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
hardkicks
Sep 20, 2015 12:28 PM
