View Poll Results: Is the Nismo slower in the 1/4 mile than the Base 350Z?
Voters: 86. You may not vote on this poll
Originally Posted by Hoooper
actually, with large rotors and good calipers, brakes WOULD be more effective. they use chutes because the equivalent braking force needed would lock up the tires AND having rotors on the driveline increases parasitic loss, which is especially evident in cars with high HP (read: cars that need a parachute).
Quit digging for reasons to start an argument.
Originally Posted by 2007-Z
In this thread I will show the difference in vehicle weight between the Nismo and the base model Z due to downforce at 103 mph. Downforce is no different than physically adding weight to a vehicle, it's just achieved through aerodynamic means instead.
That's 154.89 lbs. difference in vehicle weight at 103 mph. Basically like having another passenger (either a small guy or a big girl). Is that weight enough to affect the trap speed and ET of a 13 second car? You tell me.
Slower ET/trap could result from increased rolling friction and increased aerodynamic drag. Nissan indicates the same 0.30 coefficient of drag for the Nismo 350Z as the standard/enthusiast/touring 350Z, so there should be no impact there. Rolling friction however does depend on the normal force.
According to Wikipedia, rolling resistance for an automobile on tires on a smooth road is roughly 0.01. Lets say its double that at a drag strip. At 100mph, for your calculated ~150lbf increase in normal force, that would give 3lbf increase in rolling resistance. In comparison, at 100mph, aerodynamic drag would be on the order 300lbf, and the total rolling resistance on the order of 70lbf. So the impact of increased normal force due to aerodynamic downforce in this case would be less than 1%.
Originally Posted by kuah@splparts.com
I see where you are coming from, but there is a fundamental error in your argument. The equation of motion in the horizontal plane in this case factors only in the mass of the vehicle, not its weight or normal force. Mass is a constant, you cannot add to mass; weight or normal force however is not a constant. The definition of weight is the mass * acceleration due to gravity, and since aerodynamic force is not a gravitational force, technically there is no increase in weight. What you are discussing is the normal force.
Now, I looked into the fundamentals of downforce vs. drag and found this article from tuner performance:
http://www.tprmag.com/issue/13/13_aerodynamics.shtml
After reading this article I conclude that Nissan is either lying about the coefficient of drag for the Nismo, or it's a typo/mistake. For one, how does the Nismo have the same coefficient of drag as all the rest of the models (.30), but the Grand Touring has .31 instead of .30 with that little spoiler vs. that huge spoiler? Both models have the undercarriage package as well. It's not possible. I quote:
Originally Posted by Tuner Performance
Just like everything that's good for you, there's always some sort of negative that comes along with something positive. In this case, downforce's arch enemy is called "drag." Where downforce is like a pair of hands pushing down on your car, drag is like a big parachute trying to pull your car backwards. In the game of straight line acceleration, anything that holds you back is robbing horsepower, time, and peak performance.
Wings naturally produce both downforce and drag-the best wing designs maximize the most downforce with the least amount of drag penalty. Not only do you suffer some degree of drag with a wing, but any surface that impedes, upsets, or traps air will produce drag.
Unless you are dealing with the kind of power that smokes the tires (we're not talking about lightly spinning them in 4th gear, but real smoke-spewing, unintentional-drifting-at-150mph-in-astraight- line type power), a rear wing will only slow you down.
the underbody package reduces drag, the underbody package is there to decrease lift by smoothing the air flowing under, which in turn reduces drag. i think that helps even it back out to the .3
Reducing underbody drag will not overcome the drag produced by a big airfoil. There is little room for improvement there on a Z, any model. Just take a look under your car sometime. Which is why the Grand Touring has a coefficent of .31 even with the underbody package and having that little spoiler. How much drag do you think that little spoiler adds? (I'd guess next to nothing) So how much drag do you think the underbody package recovers since the GT spoiler still adds to the coefficient of drag even after the underbody kit? Obviously not enough to lower the CD for the GT with a little spoiler...
Originally Posted by SOLO-350Z
And we wonder how the Z has a lower CO than a Corvette C6. LOL.
It's all in the design.
Post away, I'm waiting for a response from Nissan as well as a few other places in regards to this. I'll be posting their responses here.
All 350Z trim levels have the same body design, so that comment makes zero sense.
Ummm all in the design of the body kit. Wow are you really that lost.
Kuah, it's okay, this guy argues to no end with everyone on this site because he always thinks he is right.
Go get a timeslip.
I have done more research on this and I will concede to your argument in respect to mass vs. weight. I actually found an article on a website about sailing where they were able to increase the weight with aerodynamic downforce which allowed them to increase the size of the sail which allowed them to reach faster speeds since the added weight didn't require more force to move. But, with the added downforce came added drag, but the difference in sail size overcame the drag (essentially having a bigger engine).
So how can the Nismo not produce more drag when the downforce difference is quite large? Also, how can the Grand Touring have more drag with that little spoiler? I may email Nissan and ask them this.
You don't see me arguing now do you? Others have even said also that is all you do is argue. Anyone can research your posts.
Calling people names now? Wow.
http://www.nissanusa.com/z/specifications-coupe.html
It states 0.30 for the standard/enthusiast/touring and Nismo, but 0.29 for the Grand Touring.
I did not remember seeing the .31 number, so I looked it up on Nissan's website again:
I would think that the Nismo spoiler adds a lot more though. I'm sure that I'll get a detailed response from Nissan about the aerodynamics considering that I had to provide one of my VIN numbers from my two 07' Z's in my contact information, and added the second just because. I'll post whatever they say to me here if it's relevant to this discussion.
Isn't there some kind of forum rule about stalking/harassing members? You're too childish to keep an argument contained within that single thread and you have to carry it into every thread the member posts in? Grow up kid. If all I do is argue as you say then why don't you stay the hell away from me? Perhaps because you're looking for an argument?
Stay away from me. Can I say it any more clearly?
I have searched your thread? lol. That is too funny. Anyone can see you don't argue with just me, you argue with almost every single person on this site and the admins are already watching you. Keep it on.
Kid? Funny, I am even older than you.
Thus far 45% of the voters disagree with the 25% that you voted with... So who's wrong here? The majority? We'll see what Nissan says. Apparently I'm not the only person who thinks he's right since you argue just as much as me. Hypocrite.
Go get a timeslip.
Go get a timeslip.
/thread
Sooo..I will go ahead and do a search on your threads...and prove how annoying you are.
Threads 2007-Z has been hostile in.
https://my350z.com/forum/showthread....82#post3581282
https://my350z.com/forum/showthread....38#post5085438
https://my350z.com/forum/showthread....11#post5073011
https://my350z.com/forum/showthread....12#post5093712
https://my350z.com/forum/showthread....65#post5089665
https://my350z.com/forum/showthread....14#post5089014
https://my350z.com/forum/showthread....98#post5119298
https://my350z.com/forum/showthread....02#post5140402
https://my350z.com/forum/showthread....45#post5156645
https://my350z.com/forum/showthread....51#post5156151
https://my350z.com/forum/showthread....31#post5147931
https://my350z.com/forum/showthread....88#post5204288
Originally Posted by Gooey
Yea lets just talk about timeslips. Your timeslip says 13.5. Thats it. Thats all your car + driver is capable until proven wrong. Dont claim to others your car can be a low 13sec car by what others have achieved. Lets see you replicate the same timeslips then you can argue afterwards. Until then your car is on part with a stock automatic HR Z and a Nismo Z. Case Closed
/thread
/thread
I will be headed to the track in the next few weeks. So it's all good. I will put the stock filters back in before I go.
Originally Posted by GetYouSum350z
i raced a nismo stock for stock on the highway 30 to 150, my car had a steady pull the whole time, ended up beating him about two cars. It had alot to do with down force i think.
