Drag NHRA, IDRC, IHRA, NDRA
APS Extreme G35 first time at the track
Old Sep 6, 2008 | 10:03 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Default APS Extreme G35 first time at the track
Well first time at the track with this setup at least. For details on my build see here. The car has absolutely no weight modifications and still has AC and navigation on it. its also a 6mt
https://my350z.com/forum/shop-builds...treme-g35.html
Anyways, I finally made it to the track yesterday with some ET Street Bias Plys on my G35. I managed a 11.71 @ 125mph with a shitty 1.8 60 foot. I cant seem to keep the car from bogging on the launch even with a 6k rpm clutch drop.
The good news is that ths stock axles held up pretty well with 550whp
Edit: Here is the video
http://www.mr2turbz.com/videos/cpv35.wmv
Old Sep 6, 2008 | 10:08 AM
coachk's Avatar
coachk
Nothing wrong with having an 11 sec "luxury" car.....good job
Any vids
Old Sep 6, 2008 | 10:51 AM
Lots and lots of hard work on that motors. Congratulations on making the top-30.
Old Sep 6, 2008 | 10:54 AM
Sleepy79's Avatar
Sleepy79
tire pressure?
Old Sep 6, 2008 | 11:21 AM
Blackbird CPV35
Originally Posted by Sleepy79
tire pressure?
20 psi, felt like an old buick on the big end of the track
Old Sep 7, 2008 | 03:43 AM
Sleepy79's Avatar
Sleepy79
try increasing the pressure, you might be getting too much initial grip causing the engine to bog down
Old Sep 7, 2008 | 04:16 AM
coachk's Avatar
coachk
You can't do a 6k clutch drop and expect anything but bogging....Probably not a good idea to do that again... I don't have a MT so hopefully some of the better launchers will chime in and give you some tips.Seems to me like you just need to learn how to feather the clutch and control the gas pedal when launching that hard
Old Sep 7, 2008 | 06:23 AM
Blackbird CPV35
i agree, its definitely a driver issue. I need more seat time in the car but the clutch is very touchy and hard to feather.
Old Sep 7, 2008 | 10:02 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Congrats Jason, nothing wrong with back to back 11 second passes your first time out! I know how difficult it is on these clutches, but you have to feather it out a bit. You could also setup your two-step to build some boost at the line, but it will take a bit of time to find the line between tire-spin and bog. What size ET Streets?
Old Sep 7, 2008 | 07:29 PM
bacalhau16's Avatar
bacalhau16
Utilizing your 2 step should be a big help. I would love to see some videos. Sounds like an awesome car.
Old Sep 7, 2008 | 10:25 PM
Blackbird CPV35
i believe they were 26x10.5 17"s, i was at the rev limiter at the top of 4th just as I was crossing the traps. I wonder if a taller tire would get me any better times?
Still waiting for my friend to upload the vids
Old Sep 7, 2008 | 11:49 PM
pimpsahab's Avatar
pimpsahab
Congrats and you have gobs of ET left in that trap and with the sound of it you have a lot of trap still left in it
Old Sep 8, 2008 | 05:02 AM
coachk's Avatar
coachk
According to your dyno sheet, are you still making power up to redine? If you are keep the tire/wheel setup you have because you want to finish just where you did at redline in 4th.
Old Sep 8, 2008 | 10:10 AM
scotts300's Avatar
scotts300
That's typical when mixing a bias-ply with a non bias-ply tire (front and rear).
For now. I've seen them break with 400rwhp and sticky tires. Oh the joys of big power! A taller tire would hurt your time (longer gearing) UNLESS it allows you to not hit the rev-limited in 4th as you cross the traps (i.e. you are able to keep accelerating). As you get better 60's, however, your trap will go down with your ET, so maybe leave your tire set-up and keep practicing your launch. As said previously, you need to feather a bit more to avoid bogging.
Good luck, and be safe! (remember that, at most tracks, once you go under 11.5 or over 135mph, they require a jacket and roll bar)
Old Sep 8, 2008 | 11:52 AM
Blackbird CPV35
Luckily Muncie is pretty lax when it comes to tech even though its an NHRA track, Ive even had a few friends get by on 10's without a cage at Indianapolis Raceway Park.
Old Sep 9, 2008 | 11:08 AM
Blackbird CPV35
added a video to the first post
Old Sep 11, 2008 | 06:46 AM
07JimmyZ's Avatar
07JimmyZ
nice vid... sick car
Old Sep 11, 2008 | 07:01 AM
Dynosty's Avatar
Dynosty
Nice video, I bet that was a fun race. I love when a fast car gets out on you and you are able to hunt them down.
I recognize the track... I think they lined my Lexus up against a snowmobile there.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Justin100
Nov 29, 2015 03:58 PM
SharX59
Sep 30, 2015 10:54 AM
SharX59
Sep 27, 2015 09:23 AM
