Drag NHRA, IDRC, IHRA, NDRA
2nd time at the track, video !
Old Aug 24, 2011 | 09:07 PM
cDUKES's Avatar
cDUKES
Default 2nd time at the track, video !
Hey guys.
So tonight was the second time I got my Z on the drag strip (first time was last August, so it's been a year)
after SLIGHT modding (tune) since the last time at the track, improved from my time of 14.412 to 14.111 @ 99.54 . I went with a goal to break 14 seconds and 100mph , so I was kind of frustrated. Oh well, makes me want to go back even more
track temp was about 80
Slip reads :
R/T - .485
60' - 2.162 (still trying to get 2.0)
330 - 6.013
1/8 - 9.160
MPH - 79.68
1000 - 11.842
/4 - 14.111 @ 99.54
some things i found out that i wish i knew BEFOREHAND
- lower tire pressure
- not even necessary to do a burnout with street tires
- launching in general, still trying to find the sweet spot. I still seemed to spin like crazy in first with a 2.5k launch , and i seemed to bog out when i tried anything lower.
would lowering tire pressure / no "mini" burnout help that at all?
any criticism or anything else you guys can pitch in through the video and time slips would be awesome!
[vid]http://www.youtube.com/watch?v=xsuUanJ7vMQ[/vid]
Old Aug 26, 2011 | 09:28 AM
Frosty87's Avatar
Frosty87
Try slipping clutch on the launch it will help with your wheel spin
Old Aug 26, 2011 | 05:10 PM
You are going to make 13.99 seconds or better. Keep up the good work.
Old Aug 26, 2011 | 07:49 PM
bacalhau16's Avatar
bacalhau16
It seems like your car hooks up pretty well for street tires, not a ton of spin. I think you are a little aggressive with the clutch on the launch and a higher rpm with more clutch could benefit. The car bogs slightly right now. Not a bad pass all and all. I agree that you should def be able to break 13.99 soon.
Old Aug 26, 2011 | 11:14 PM
cDUKES's Avatar
cDUKES
im heading back to school with the Z in MA when this damn hurricane passes (closest drag strip from there is in NH ) so hopefully i'll get another go at it when I come back in november. not a chance i'll be able to wait another year.
colder weather should help as well
appreciate it!
and do you think lowering the tire pressure would make any difference? I'm pretty sure I was around 33psi in the rears
Old Aug 27, 2011 | 12:51 AM
SE5spd's Avatar
SE5spd
try launching at 3500 and slipping the clutch off the line, your 2-3 and 3-4 can be WAYYY faster, try WOT shift, at least 3-4 (easiest gear shift to do imo)
Old Aug 27, 2011 | 10:15 PM
bacalhau16's Avatar
bacalhau16
If your referring to New England Dragway in NH, I wouldnt be expecting to get your best times there. The conditions on Wednesday and Friday nights suck. Your best bet is to go on Saturday or Sunday during the day. I believe it is $5-$10 more to race, but totally worth it.
Old Aug 28, 2011 | 12:06 AM
cDUKES's Avatar
cDUKES
yes I was, and thanks for the heads up. with classes, a job, and an internship finding time to take the trip from Amherst to N.E.D is going to be a little difficult.. I think my best bet is to give raceway park (englishtown, NJ) a go in November when I can get a week off.
Old Sep 7, 2011 | 06:04 AM
djamps's Avatar
djamps
I'd launch at a slightly higher RPM, engage the clutch a little faster, but don't squeeze the throttle until the clutch is fully engaged. In the vid it looks like you squeeze the throttle at the same time you engage the clutch -- this will lead to wheelspin and clutch wear. The clutch should only slip for the 1st 10-15 feet only -- it should happen pretty quickly.
An another note, either you're engaging the clutch too slowly on upshifts or it's slipping. Sounds like a 5AT with the slow engagment. Any way you can speed up the shifting will get you into the 13's.
Old Sep 7, 2011 | 10:41 AM
cDUKES's Avatar
cDUKES
appreciate the input djamps, pretty much sums up the most of the wheelspin on the launch, i wasn't waiting until the clutch was fully engaged to start giving it more throttle. between this and just straight up quicker shifts, hopefully ill be making 13 second passes next time
Old Sep 7, 2011 | 10:52 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Get off the clutch faster during shifts.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Justin100
Nov 29, 2015 03:58 PM
