Smallest size wheels that can fit on a Brembo Z
Ok, so I have been searching around these forums and found some mixed reviews from a number of different people on different wheel sizes for Brembo cars.
I'm looking to put a set of MT E/T street radials on the car, preferably a 10.5" and i've read some people saying they can get away with 16" wheels and others saying the smallest you can go is a 17" wheel.
I have no interest in removing my rear Brembo calipers since my car is still a street car.
Wondering what you guys with Brembos setups are actually running and having success with. Failures too.
I ran 16" Z32 wheels in the REAR with my Brembos, just had to shave a touch of the "spline" from the casting on the inside of the wheel. Other guys run RX7 FD 16" wheels in the rear. So, to ATQ, some 16s can work.
Lots more talk about this in these two threads:
https://my350z.com/forum/drag/181127...al-set-up.html
https://my350z.com/forum/drag/411723...ag-wheels.html
ya 16"s clear. I swapped my rear brembo with 03 stock brakes. absolutely no difference in stopping power. unlimited choice in rear tires.
the hard part is the fronts. you need a 17" skinny and there are no cheap rim options for that.
There are 2 versions of the FD wheels which look the same but the back of the spokes are a little different. The older version is lighter but more fragile, while the newer one is couple of lbs heavier but stronger.
Thank you everyone for your input!
Yep, I have the older lighter ones. Out of 4, 2 of them were cracked badly. The 'good' 2 are still holding up for me. The original owner probably hit something.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
