unfortunately more questions about importing a Z from the USA...
Old Jul 18, 2008 | 08:53 AM
  #101
WonJeremy's Avatar
WonJeremy
yea clean install.
no blown fuses.
no visible wires.
have to flip the parking light switch on for the radio backlight to come on.
so tell him to watch out for that.
Old Jul 20, 2008 | 10:24 PM
  #102
BC350Z's Avatar
BC350Z
does anyone know what happens if you get a 06 MT and it turns out you have the oil consumption problem?
will the local dealership replace it for you?
Old Jul 21, 2008 | 09:04 AM
  #103
g35koupe's Avatar
g35koupe
Call Infiniti Canada before hand and see what they say. Some dealers will refuse to service an American car that was just imported, or they will charge you for the work and tell you to deal with Infiniti Canada/USA for reimbursement.
Ideally, you should have the car checked out and serviced before you buy it. Ask the dealer you are buying it from if you can take it to the local American Infiniti dealer to have it looked over.
Old Jul 21, 2008 | 10:29 AM
  #104
BC350Z's Avatar
BC350Z
Thanks for the info g35
as I recall, you can't really tell if the car has an OC problem right away is that correct?
you have to go back after a certain mileage and see if the car consumed more oil than it supposed to
Old Jul 21, 2008 | 12:11 PM
  #105
g35koupe's Avatar
g35koupe
That's correct.
Also, depending on how well the car was maintained, you may also be able to ask for the service history to see if the problem was addressed. Try calling Infiniti USA with the VIN of the car to see if it would be in a batch that could have had the problem, or if it was brought in and had the issue addressed.
Old Jul 21, 2008 | 03:12 PM
  #106
BC350Z's Avatar
BC350Z
Originally Posted by g35koupe
That's correct.
Thanks a lot!!
btw, do you know how to fix up the DRL yourself?
I tried contacting a member here (advanss) but he never replied
if possible, could you write up a step by step how-to for installing DRL
thanks in advance!
Old Jul 21, 2008 | 05:17 PM
  #107
maddindian's Avatar
maddindian
yeah that's my issue too, I don't know which wires to tap into. I think they are all located in the fuse box by the driver-side foot-well. However, I do not know the following details:
1. wire that gives signal when the car is on
2. wire that sends power to the parking light
3. power source for the parking light
Also there could be a single wire that could be 3) & 1).
I'm thinking of just giving it to CDN tire. I will ask them if they are familiar with 350Zs.
Old Jul 21, 2008 | 08:17 PM
  #108
g35koupe's Avatar
g35koupe
Thanks a lot!!
thanks in advance!
Sorry, I never did the DRL's myself. I have a mechanic I trust to do it. But I noticed that you're in BC. Why not give Ztune (www.ztune.ca) a call? They do awesome work, and they can probably do the DRL install for you at a reasonable price.
Old Jul 22, 2008 | 01:40 AM
  #109
BC350Z's Avatar
BC350Z
Thanks!
I wasn't aware of them
but I am now
Old Jul 22, 2008 | 09:44 AM
  #110
maddindian's Avatar
maddindian
update: so i asked the Cdn tire in Waterloo if they do DRLs on the 350Z and they said no. They told me to go to the Nissan dealer.
Old Jul 22, 2008 | 11:59 PM
  #111
StEeElNuTz's Avatar
StEeElNuTz
ok for the DRL this is what my friend did :
1 - remove the bumper
2- remove the headlight
3 - find the slot in the plastic box attached to the headlight that is powering the parkings lights
4- get a wire that will pass from both headlights to the fusebox under the battery compartement. (you will need to remove some plastic around the battery cover too)
I will pass inspection and remove all that after. It's only temporary and I didn't cut any wire.
Old Jul 24, 2008 | 01:07 PM
  #112
maddindian's Avatar
maddindian
To those who bought the Zs, did you ahve to perform e-test and safety prior to having it registered in Canada?
I got the inspection done at CDN tire but they claim I need to do e-test and safety before I can get plates for it. Is this true?
The car is a 6 month old '07 with 6k miles on it
Old Jul 24, 2008 | 04:10 PM
  #113
g35koupe's Avatar
g35koupe
Yes, emissions and safety must be done (at least to register a vehicle in Ontario).
Old Jul 25, 2008 | 07:24 AM
  #114
maddindian's Avatar
maddindian
Thanks. I had incorrectly assumed that was for older cars only, not relatively new ones.
So I had the Nissan dealer perform the DRL installation, and they screwed up! The radio backlight does not work anymore (when the car is on) unless I turn on the headlights via the stalk.
So they are taking another look at it.
Old Jul 25, 2008 | 09:03 AM
  #115
2TH PWR's Avatar
2TH PWR
Wow! A Z at Canadian Tire. Now that's thrifty.
Old Jul 25, 2008 | 11:58 AM
  #116
maddindian's Avatar
maddindian
from what i read, everyone takes their Z's to CDN tire?
i ended up taking to the Nissan dealer and they were just as useful (sadly) but cost more.
Old Jul 28, 2008 | 01:14 PM
  #117
StEeElNuTz's Avatar
StEeElNuTz
I just received the form 2 and would like to know if I just have to call to any CDN tire and get an appointement to have the inspection done?
Old Jul 28, 2008 | 11:21 PM
  #118
striker27's Avatar
striker27
One day I hope to install DRL!!!!
OH well!!!
Old Jul 29, 2008 | 06:17 AM
  #119
g35koupe's Avatar
g35koupe
That's correct.
Old Jul 29, 2008 | 11:10 AM
  #120
240Zplus110's Avatar
240Zplus110
I just had my engine replaced in my imported 2006 Z which had the oil consumption problem.
PM me if you want more details.
