03 350 Recommended Transmission oil?
Old Nov 23, 2009 | 05:27 AM
H22paul's Avatar
H22paul
Default 03 350 Recommended Transmission oil?
I was told to look into this because it might have an attitive.
And where els is better to ask.
which transmission oil do you recommend in an 03 350Z.
Old Nov 23, 2009 | 08:06 AM
4DGS's Avatar
4DGS
I believe the ONLY way to go is with Nissan's brand. It's called J matic I believe, it use to be called S matic, but they changed it for some reason. I might have the two names mixed up though... J could be the old and S could be the new. Anyways, I've heard this is the only way to go when changing trans oil in our cars.
Someone correct me if I'm wrong though.
Old Nov 23, 2009 | 10:29 AM
Nominee's Avatar
Nominee
Funny..I just bought 4 bottles this morning!
GL-4 75/85w - OEM Nissan MTF
Old Nov 23, 2009 | 04:14 PM
H22paul's Avatar
H22paul
aight thanks alot.
Old Nov 25, 2009 | 06:23 PM
gyotar's Avatar
gyotar
Anyone know of a source for Redline Trans/Diff oil in the GTA?
Old Nov 25, 2009 | 08:31 PM
Sleepy79's Avatar
Sleepy79
part source?
i'd go with amsoil personally
Old Nov 26, 2009 | 05:21 AM
gyotar's Avatar
gyotar
Partsource has Amsoil? They don't carry Redline.
What viscosity should I get if I go the Amsoil way.
With Redline I'm able to mix to get the OEM viscosity.
Old Nov 26, 2009 | 06:53 AM
clubhopper's Avatar
clubhopper
stagefourmotorsports.com carries every type of redline oil
they are setup in ontario
Old Nov 26, 2009 | 07:04 AM
ed@aph's Avatar
ed@aph
Vendor - Former Vendor
we always have redline n motul gear fluid in stock
www.advancepowerhouse.com
Old Nov 30, 2009 | 06:27 AM
H22paul's Avatar
H22paul
Any sugestions on how often to change the tranny oil? Or if to just top it up when it's low?
Old Nov 30, 2009 | 07:39 AM
ed@aph's Avatar
ed@aph
Dealers saids every 80k, we do recomm. most of fluids change(tranny, diff, brake, clutch) every 50k-60k, it up to the owner, so that its easier to keep track of.
although, clutch n brakes are recomm for every 100k.
Old Dec 1, 2009 | 09:08 AM
H22paul's Avatar
H22paul
Sweet thanks for the info.
Old Jan 29, 2010 | 05:05 PM
shift@9krpm's Avatar
shift@9krpm
Mixing Redline MTL & Nissan MTF 50/50 Has anyone tried this??
Old Jan 30, 2010 | 06:33 AM
ed@aph's Avatar
ed@aph
MTL's velocity doesnt sound too right on a nissan MT, unless you are using it during cold winter weather
Old Jan 30, 2010 | 06:35 AM
Jay'Z's Avatar
Jay'Z
Nissan/thread
Old Jan 31, 2010 | 06:33 PM
SC350ZR's Avatar
SC350ZR
I'm going AmsOil in both the 6MT and the diff this spring.
I have been using their motor oil for 35K and runs great.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
