OEM Brembo Rotors and Rim fitment question
Old Nov 25, 2011 | 08:44 PM
MSP-D's Avatar
MSP-D
Default OEM Brembo Rotors and Rim fitment question
I recently tried to put on my winter rims and tires and ran into a little problem. So on the OEM Brembo Rotors there is this extra bolt/nut that sticks out from the rotor. This bolt is causing my winter rims not to fit....I have included a picture below in case I am not describing the issue properly. As you can see on the rotor on the left side in the picture there's this extra nut that sticks out
My question is, is there a purpose and use for this bolt? is it something that I can just remove? or grind off?
Old Nov 25, 2011 | 10:18 PM
bender's Avatar
bender
Don't grind it. I believe you can just unscrew it or you can pull it out. I'm not sure which because i've never had to remove them, but they are meant to come off easy. You don't need them. They are just there to keep people from mixing up the fronts with the rears.
Old Nov 26, 2011 | 09:29 AM
Duckeee's Avatar
Duckeee
lol just unscrew. it's there so that people do not mix match the rear wheels to the front.
Old Nov 26, 2011 | 09:52 AM
MSP-D's Avatar
MSP-D
didn't realize it was something that could be unscrewed easily...it was late at night, lol
thanks
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
