Would 1 day matter btwn dynos?
Old Dec 11, 2004 | 10:06 PM
Z BOY's Avatar
Z BOY
Default Would 1 day matter btwn dynos?
I've read that the most accurate way to measure the effect of a mod is to dyno, then install mod, then redyno the same day on same dynamometer; but with header install, for instance, which can require 8 hours of install time, making two dynos on the same day can be difficult. What if i redyno the next day?
Just how reliable is the typical dynamometer from one day to the next if sae corrections are made each time?
Old Dec 12, 2004 | 02:25 AM
shinz's Avatar
shinz
you should probably go when all weather conditions are the same or very similar to the day of your original dyno.
Old Dec 12, 2004 | 08:42 PM
Z BOY's Avatar
Z BOY
any other opinions?
Old Dec 12, 2004 | 08:51 PM
JimRHIT's Avatar
JimRHIT
matt ... with your luck on the dynos I would be worried about 10 minutes .... your car just doesnt like to show gains. I suggest only using the dyno to make sure your a/f is cool ... just ignore the numbers as long as the car feels faster ...
Old Dec 12, 2004 | 09:05 PM
Wicked4u2c's Avatar
Wicked4u2c
Default Re: Would 1 day matter btwn dynos?
Does it matter? It seems that this way is just to "cheat" the actual horsepower numbers... We all know when you install a mod when you i.e. an intake system you can def feel the changes. But what happens 1 week 2 weeks later? The car feels the same again. What I am trying to say is that it shouldn't matter what your DYNO numbers really say because 2-3 even 4 weeks from now your car will have the horsepower it has and their is no changing that. Am I making sense?
Some people say that the ECU needs to adjust, say you install the intake system. DYNO THE CAR RIGHT AWAY, and get 240whp say in 1 week later you dyno the car again and you lose horsepower, and are now at 235whp. Sure, you can brag and say I got 240whp but reality is that you are now handicapped 5whp and probably don't even know it. So its cool to say that you dyno your car 1 month later that day and see your power and you can proudly say I have xxx HP. But maybe doing back to back runs from just a fresh install maybe inaccurate, unless ecu tuning is involved.
Old Dec 12, 2004 | 11:13 PM
phunk's Avatar
phunk
CJ Motorsports
to ensure consistency on a roller intertia dyno make sure that they properly center you car before strapping. For consistent results this is a must and lots of people have no idea what im even talkin about.
Park the car on the rollers and just put wheel chocks in. Then you turn off the E-Brake and turn off the dyno brake and spin the rollers with your foot until the car is done centering itself. This is a must with RWD cars otherwise the chances of you strapping thec ar at a slight angle are high and that angle increase tread resistence and reduces HP.
Old Dec 12, 2004 | 11:24 PM
Z BOY's Avatar
Z BOY
interesting; i've never noticed that being done, but maybe i wasn't paying attn.
Old Dec 14, 2004 | 08:16 PM
Z BOY's Avatar
Z BOY
z
Old Dec 14, 2004 | 09:20 PM
350G's Avatar
350G
On the AWD Mustang dyno, they did something similar to let the car align itself. Needless to say, it didn't matter. The d@mn Supra (Greg @ Injected Performance) merely lost traction (centered) and dynoed over 500whp. It was crazy . . . bits of rubber flying everywhere when dynoing *LOL* Hate to see if he actually was able to get a grip
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
